930 floating rotors
am i correct that for my '78 930, no one except oem supplies replacement
front floating rotors? am i also correct in thinking that "upgrading" the brakes would lessen the value of this crusty jewel? thanks for your time,,,, jp |
Option
I know at one time Pelican had them and then when an order was placed they were "not available". I have heard that Vertex Auto may have some stock left if Pelican does not in these floating rotor types. Give them a call and maybe you will be lucky.
At this point you are searching for a warehouse that has left over inventory otherwise Porsche would be your only option as far as I know. Best of luck, Bryan |
If you make a change to something different that would be more durable, I would still keep these around. |
Wrong.
They are still available. Expensive but without a dought the best way to go... nothing to upgrade here. |
I believe Brembo make some replacements...304mmx32mm
Part number XA3.33.10/11 http://forums.pelicanparts.com/uploa...1234819225.jpg Regards John |
Are these rotors compatible with the later (I have an '87) calipers?
You have a one-piece rotor that encompasses the hat into the rotor to save cost. |
Thanks Steve. I suppose that is one fewer "upgrades" I have to add to my list then. :)
It won't be cheap |
Got it, thank you for the clarification. I'll put it on my maybe list!
I am not really sure how,,, i'm not very good at managing my stuff. I now
have: 6 floating rotors, 3 left, 3 right, and a set for the rear. I guess i'll have to keep the car. |
| All times are GMT -8. The time now is 04:42 PM. |
