SAIGON 68
johnnywishbone's Avatar
930 floating rotors
am i correct that for my '78 930, no one except oem supplies replacement
front floating rotors?
am i also correct in thinking that "upgrading" the brakes would lessen the
value of this crusty jewel?
thanks for your time,,,, jp
Old 02-16-2009, 08:02 AM
After the next project
x98boardwell's Avatar
Option
I know at one time Pelican had them and then when an order was placed they were "not available". I have heard that Vertex Auto may have some stock left if Pelican does not in these floating rotor types. Give them a call and maybe you will be lucky.
At this point you are searching for a warehouse that has left over inventory otherwise Porsche would be your only option as far as I know.
Best of luck,
Bryan
Old 02-16-2009, 08:41 AM
The factory floating rotors are unique to the '78-'79 930's and there isn't a cheaper replacement item. While not cheap, these are available outside the Porsche dealer network.
If you make a change to something different that would be more durable, I would still keep these around.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-16-2009, 09:39 AM
Wrong.
They are still available. Expensive but without a dought the best way to go... nothing to upgrade here.
Old 02-16-2009, 10:42 AM
I believe Brembo make some replacements...304mmx32mm
Part number XA3.33.10/11
Regards
John
Old 02-16-2009, 01:22 PM
TroyN's Avatar
Are these rotors compatible with the later (I have an '87) calipers?
'01 996, w/ LN IMS!
Past: '96 993, '98 986, '82 911, '99 986, '87 930, '86 951, '85 911 GTS3 race car
Old 02-16-2009, 01:36 PM
Nossir,..those rotors are made for the two-piece floating "flat" hats used on those early 930's.
You have a one-piece rotor that encompasses the hat into the rotor to save cost.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-16-2009, 03:35 PM
TroyN's Avatar
Thanks Steve. I suppose that is one fewer "upgrades" I have to add to my list then.
'01 996, w/ LN IMS!
Old 02-16-2009, 03:45 PM
Bill Verburg's Avatar
Steve is correct but if you really really wanted you could replace your 930 front hubs w/ 911hubs and then use the '78-80 930 hats and rotors and wheel spacer.
It won't be cheap
Bill Verburg
Old 02-16-2009, 03:46 PM
TroyN's Avatar
Got it, thank you for the clarification. I'll put it on my maybe list!
'01 996, w/ LN IMS!
Old 02-16-2009, 05:24 PM
SAIGON 68
I am not really sure how,,, i'm not very good at managing my stuff. I now
have: 6 floating rotors, 3 left, 3 right, and a set for the rear. I guess
i'll have to keep the car.
Old 11-18-2009, 08:26 PM
