3.6 conversion question
Does anybody know if the gaskets for the timing chain covers for the
3.6 left & right are the same part. It looks as if the passenger side gasket needs to be "forced" in around the last corner., where as the driver side drops right in. Thanks ![]()
looks different to me do a search on the hosts parts and see if there is different part numbers, Kevin
ya I checked, the part numbers are the same, but this does'nt seem right.
you sure you dont have turbo covers?
964-105-181-01-M260 Chain Cover Gasket, For Left or Right Side, 911 Carrera 2/4 (1989-98), 911 Turbo (1993-97), Each
Brand: OEM [More Info] $10.00 930-105-191-03-M17 Chain Cover Gasket, Left, 911 Turbo (1989-92), Each Brand: Victor Reinz [More Info] Kevin |
maybe they just screwed up and sent two of the same, Kevin
The 964 105 108 cover is for "964 C2/C4/Turbo (1989-1994)" which superseded the old part number.
10-0912-181-M194 looks to be the gasket (and hardware) that you need. Maybe.
'84 911, some sort of red color '05 Subaru WRX wagon Last edited by richde; 02-17-2009 at 02:09 AM.. |
