rodoredas's Avatar
Double sided tape too easy, needed more complicated solution!
a few weeks ago i posted item about attaching 2.7 emblem to engine vent and double sided tape seemed to be the answer, but this appeared way too easy and a 5 minute job. I wanted something more complicated that would take ages.
So i fabricated a small metal plate the length and width of the emblem with a small narrow raised ridge that would sit between the vents.
The emblem is glued to the metal plate which results in having a larger surface area of the emblem actually in contact with the glue. The small ridge fits neatly between the vents and washer and nut holds every thing in place.
oh well, i had fun doing it!
oh, almost forgot - i did use some double sided tape between the back of the plate and the vent just in case, don't want to scratch the vents now!
cheers
shane
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 02-22-2009, 03:20 AM
Driver8's Avatar
That is what I love about the people on this board. They never take the easy way out. Nice work!
Old 02-22-2009, 03:51 AM
Almost Banned Once
sc_rufctr's Avatar
Great job... The badge will defiantly stay put.
Old 02-22-2009, 03:52 AM
The double sided tape alone method would only be for attaching the emblem to a aluminum grill with the factory mounting plate on the grill, to use this emblem on any other type of grill one would need to fabricate a mount, like you did. Good job!
Old 02-22-2009, 09:51 AM
Zeke's Avatar
All that trouble for a 2.7 ??
Old 02-22-2009, 12:41 PM
DW SD's Avatar
time for a 3.6 install. that'll keep you busy for a few months.
1971 RSR - interpretation
Old 02-22-2009, 03:28 PM
RETIRED
Joe Bob's Avatar
You misspelled "3.2"...
2012 ML350 3.0 Turbo Diesel
Old 02-22-2009, 04:29 PM
rodoredas's Avatar
yeah 3.2 one day maybe, my 2.7 is going fine so is the sporto, would rather keep it that way if I can. considering buying spare 2.7 and spare sporto, or 3.0/3.2 but then a new gear box too, food for thought.!
we don't have all that anti pollution stuff (and we have 11 blade fans) that seems to cause so many problems in the US with over heating.
it's all good fun.
cheers
Shane
Old 02-22-2009, 04:38 PM
