kodioneill's Avatar
85 carrera much faster than 82sc
i own a 1982 sc . today i test drove a 85 carrera. why does the 85 seem so much faster that the 82? does 15 more horsepower make it seem that much quicker? is there a problem with the sc? dist advance, injectors, etc...
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-18-2009, 04:56 PM
Senior Member
Superman's Avatar
An '82 SC should clobber an '85 Carrera. Just ask any SCWDP member.
Mocha 1978 911SC. "Coco"
Old 02-18-2009, 05:27 PM
4flyboy's Avatar
Please!
Consider the source. This guy only has a couple of posts.
Geez.
Wait a second,,,,,,,,,Rats!
SCWDP members lie!
S.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-18-2009, 05:42 PM
trak ratt's Avatar
Unless Euro SC '85s have 27 more HP. Depending on magazine, road tests showed about 3/10-4/10s secound in 1/4 mile. Out on the road or track very little difference. Were either cars targas?
Old 02-18-2009, 05:50 PM
Free minder
Aurel's Avatar
I`ve never driven a carrera, but I heard that the EFI gives better throttle response than the CIS on SCs. Also, are you comparing stock to stock? A chip and cat bypass or SSI will give a big advantage to the carrera.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
DanielDudley's Avatar
Did you uncork the exhaust ?
Old 02-18-2009, 06:10 PM
kodioneill's Avatar
yes, stock to stock. i'm thinking of buying another 911 so i road tested the 85 today. it pulls so much harder than the sc between 4000 and 6500 i was amazed.
1982 chiffon 911sc
kodioneill's Avatar
yes, i took out the cat.
1982 chiffon 911sc
Old 02-18-2009, 06:11 PM
Free minder
Aurel's Avatar
How much advance are you running on your SC? On mine, 5 deg idle is not enough, but ~9 deg makes her wake up at higher rpms.
Old 02-18-2009, 06:16 PM
fastfredracing's Avatar
I dont really think they are much faster, The carerra's power band seems more smooth. Last summer, I drag raced a bone stock 80 sc against my buddies chipped@ cat bypassed carrera, and he did pull away from me, but not by very much
No left turn un stoned
Old 02-18-2009, 06:43 PM
kodioneill's Avatar
have not yet checked the timing or the advance curve. the car is new to me and winter is on us hard up here.
1982 chiffon 911sc
Old 02-18-2009, 06:57 PM
Also check your gas pedal and linkage all the way back to the engine. I'll bet you are not getting full pedal. Check it at the engine. Others have written about it. You could do a search, or perhaps someone else will give a better explanation.
Old 02-18-2009, 07:01 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
3.2 vs SC - numbers
Here we go again...
Based on published road test results for US-spec 911SC and 911 Carrera 3.2:
Old 02-18-2009, 07:30 PM
Laneco's Avatar
We have an 80 with an 85 engine (steve's cab) and my 81 CIS coupe (Butters).
Drive them both back to back on a regular basis and my butt-dyno confirms the above.
Assuming both are running soundly, an 85 Motronic tears up a CIS car...
angela (SCWDP #36)
Hello
Old 02-18-2009, 07:35 PM
AutoBahned
RWebb's Avatar
CIS does not do very well at higher rpm.
It is just an older technology.
Old 02-18-2009, 09:24 PM
Originally Posted by dw1 View Post
Here we go again...
Wow, big difference to a 100mph!
1986 Targa
1968 MGB (2)
Old 02-19-2009, 12:45 AM
a.k.a. G-man
Geronimo '74's Avatar
angela (SCWDP #36)
'nuff said.
Old 02-19-2009, 12:54 AM
Your opinion does not qualify here. Only people with an objective attitude get to post on the virtues and drawbacks of CIS
Actually CIS does quite well at higher RPM's when set up properly. Yeah throttle response could be better, etc, but with a good exhaust, 964 cams, and set up well (which is not that difficult to do!), these cars are a blast!
Craigyirush - where are those figures from? The HP specs match nothing I've ever seen for either SC or Carrera (180hp and 207hp).
The U.S. SC - in stock form - is a somewhat castrated beast. The RoW 81-83 SC had 204hp. W/o a cat, you should be able to get close to that - and the difference to a 207hp Carrera won't be that noticeable. 20 some years ago I had a Euro Carrera w/231 hp and drove that back to back w/ a customers '87 U.S. Carrera (217hp ). There was def a difference to be felt, but it was in no way mind-boggling.
If the difference feels that great to you, it does sound like somethings not OK on your car.
Old 02-19-2009, 02:17 AM
durn for'ner
livi's Avatar
Random individual cars can probably differ more than between the model lines. At least for US cars. Larger difference between ROW cars generally.
Markus
Resident Fluffer
Carrera '85
Old 02-19-2009, 07:07 AM
Senior Member
Superman's Avatar
It depends. Many of the SC's that I see these days have broken or missing throttle linkage bushings on the linkage plate that sits atop the engine. Replacing those two bushings probably gives a good 20% more throttle. Big difference.
Ignition timing makes a huge difference. My 3L engine is timed to 35 degrees full advance. This is about seven degrees advanced from stock spec. Makes a huge difference.
Several P-guys got together one day a few years ago to dyno our cars. There was at least one Carrera there, and my SC had the highest torque numbers in the group. I think it made something like 174 lb/ft at the wheels, which should be about 205 lb/ft at the crank.
Still, Bruce Anderson says to buy the newest, cleanest example you can. Porsche continually made improvements. Motronic is a better fuel system. 3.2 is a bigger number than 3.0.
Old 02-19-2009, 08:39 AM
