weak system pressure on SC
My SC has been running a little poor when warm. OK when hot and cold.
So, I hooked up a fuel pressure gauge kit between the Fuel pressure distribution unit and the WUR. Turned the key on, bypass the fuel pump relay, and the pump comes on, runs for about 30 seconds and the best i get is 50 PSI. 20 PSI shy of ideal. What would you do in order of least expensive things first ??
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Did you shut off the feed to the WUR when you ran the test, it's not clear from your post.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
CIS Troubleshooting..........
I was looking for a certain post and came across yours. When your system pressure is this low (50 psi), there are two (2) things I would do: 1). Check the FP delivery pressure (max) and volume (optional). A value of 65 to 70 psi means FP is up to spec. and will deliver sufficient volume of fuel. 2). Check fuel distributor (FD) regulator. Check this only if you the FP passed the test and still have a low system pressure. Be very careful not to lose the tiny components. Keep us posted. Tony |
N-Gruppe doesn't exist
never underestimate the value of a clear fuel filter
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
