austin552's Avatar
Question Hand Throttle Cable?
Where does the hand throttle cable exit the tunnel?
1974 911s
Old 03-10-2009, 07:39 AM
Peter Zimmermann's Avatar
You don't have a separate cable for the hand throttle, the lever near the handbrake operates a "shoe" that fits over the throttle rod and pushes against an adjustable stop that slides on the rod that passes through the tunnel.
Keep the Shiny Side UP!
Pete Z.
Old 03-10-2009, 07:44 AM
austin552's Avatar
So where does the rod exit the tranny and how does that connect to the throttle?
1974 911s
Old 03-10-2009, 08:18 AM
AutoBahned
RWebb's Avatar
get under there - after it is on stands, not just a jack - and look at the driver's side of the tranny -- you will see he assembly -- the thing that looks like a coathanger with a loop in it is the throttle rod from trans. to motor; on the other side of the articulated, ah, gizmo is the part that the nylon hand throttle piece hooks on to further forward.
search for pics of the tunnel exits
and see the diagram of the whole setup in the PET or service manual
Old 03-10-2009, 10:55 AM
