RG5 RG5 is offline
Recommendations for stock looking twin outlet exhaust tips .. show us yours...!
Hi,
Recently it was suggested to me that I should replace the oval twin exhaust tips on my car for something less "aftermarket" looking and more inconspicuous and better integrated into the rear end of the car.
The trouble is I am not sure what to look for. The current tips and attached to 2.5" section of pipe connected to a flange plate that mates with a similar flange connected to the side of the muffler. I am looking for some examples of tips to replace mine with.
Any ideas welcome. Here is my car:
Old 01-23-2009, 04:31 AM
cdrik915's Avatar
What do you think of round tips ?
Perpendicular to the bumper (yours are lateral).
LIGHTER = FASTER !!!
Old 01-23-2009, 07:58 AM
Less brakes, more gas!
euro911sc's Avatar
I have a classic sport muffler on my SC... kinda looks like this:
Very stock looking, but not period of course... good sound on my 3.0.
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 01-23-2009, 10:56 AM
Retired Member
Brian 162's Avatar
Here you go. 3 litre with SSI's using a stock muffler with larger stainless tips added.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 01-23-2009, 07:12 PM
RG5 RG5 is offline
Thanks guys,
I think what I might do is take off the tips and flanges and first get back to the underlying 2.5" pipe off the muffler. Then I think a welded extension of polish stainless 2.5" pipes is the way to go. I think these will be flush or slighly inside the rear bumper outline, and angled parallel to the rear valance. I just want a less "in your face" integrated look. THen I will fit a new painted valance around the new outlets to get more of an OEM look.
If anyone has a picture along these lines it would be appreciated.
RG5.
Old 01-23-2009, 07:30 PM
Administrator
Jack Olsen's Avatar
I used to have stainless tips and -- like you -- thought they looked a little funny. I ended up going with simple, angle-cut aluminized steel (or whatever the pipe is made out of). I like the less flashy look.
Old 01-23-2009, 07:41 PM
efhughes3's Avatar
I don't know...."flashy" ain't too bad, just make sure they don't hang out too much:
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-23-2009, 08:02 PM
175K911's Avatar
Not OE, but something a bit different
This is one of Ben's M&K 911R mufflers with different tips. BW Motorsport Yellowbird bumpers.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-24-2009, 04:42 AM
Metal Guru
911nut's Avatar
Originally Posted by 175K911 View Post
Very nice!
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-24-2009, 05:57 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
Stock tips on both sides...
not so stock....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 01-24-2009, 06:02 AM
RG5 RG5 is offline
Did a bit of work on the car today. It turns out that the tips are screwed to a 2.5" pipe that is attached to a flange that meets the flange connected to the muffller. This seems a lazy way to weld up new tips. Anyway, I previously could not remove the tips as the screw is rusted up. So I removed the tips at the flange plate and drilled out the screw and removed a the tips. This left the shorter section of pipe which I sanded and polished up with Autosol.
This is how it looks. You can re-attach the flange and change the direction so the tip is angled straight out or slightly down. As the pipe is a bit short of the rear bumper I angled it down. It looks a bit agricultural bit it is a start. Tell you, it takes a while to get used to the smaller pipes!!
Old 01-24-2009, 07:12 AM
chris57's Avatar
Here is my homemade duals
1985 911 "turbo look"
2008 Foose F150 (free truck)
2002 Mercedes Benz S55
Old 01-24-2009, 08:14 PM
RG5 RG5 is offline
Chris57,
I think that out of all these pictures, your muffler outlets are the closest to the look I want. I think I will take your pic to a custom exhaust place and get them to cut off the flanges and then put a 2.5" small extension pipe to make it look like your car. Then I will replace the vanlce and cut around the new discreet looking pipework.
Rg5
Old 01-26-2009, 01:38 AM
RG5 RG5 is offline
All, thanks for all the contributions. Yesterday I had the new tips added. The flanges were cut off and 3" polished stainless pipe was welded to the 3" pipes off the muffler. I think they look OK and fairly inconspicuous which is the look I wanted. Not to bad a solution for around AUD80!
Old 02-06-2009, 03:29 PM
Mike and Paula
84 911 WideBody's Avatar
Jack
Did I read some where you used a flowmaster muffler?
If so what pt number?
Mike
Old 02-06-2009, 03:39 PM
RG5
Very nice looking solution.
Scott
'78 SC mit Sportomatic - Sold
Old 02-06-2009, 04:02 PM
SPJ-911's Avatar
89 Carrera 3.2L
84 FXRS
Old 02-06-2009, 04:27 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
RG5 I like the ones in your first origonal post best, maybe they would look even better if you just cut them back an inch (shorter).
RG5 RG5 is offline
too late, they are gone!
Old 02-06-2009, 04:42 PM
Administrator
Jack Olsen's Avatar
Originally Posted by 84 911 WideBody View Post
Jack
Mike
I'm pretty sure it's the 80 Series, part number 389-42582 at www.Jegs.com . It used to be $99, now it $116.
Old 02-06-2009, 04:54 PM
