3.0 trans to a 2.7
Can a trans from a 3.0 SC be used in a '74 2.7? Can the speedometer be back dated to the '74 mechanical type?
Also is there a benefit to go with the aluminum case 915 over the mag case 915?
Old 02-21-2009, 12:21 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
the answers are yes and yes.
if you still have the 2.7 then the higher gearing will be noticeable as the ratios are different.
the alloy is stronger than the mag case but if your not running big power i would stay with the old 2.7 tranny.
good luck
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-21-2009, 12:27 AM
I'm considering going with a 3.0 motor and may get the trans also. I'd like to keep the engine compartment stock so I'm thinking of just using a 3.0 long block and using all of the 2.7 Fuel and ignition components. I understand that if I use a 2.7 distributor drive and the brass crank gear it should work?
Old 02-21-2009, 08:17 AM
AutoBahned
RWebb's Avatar
- the very best 915 is the late Mg models
they need to be hot rodded a bit tho
http://forums.pelicanparts.com/porsche-911-technical-forum/332597-best-year-915-transmission-post4242866.html#post4242866
Old 02-21-2009, 11:19 AM
UNDER CONSTRUCTION!
so looking at a chart on that link from rwebb, looks like ratios are the same after 74 so i was wrong on my statement above.
as far as using the 2.7 injection on the 3.0 i wouldnt, if your getting a 3.0 complete just move the ignition and regulators etc. over to the other car.
my last swap i just swapped the alt and larger fan from the 2.7 over to the 78 3.0 moved over the ignition box. and had to move a couple of pin connections on the engine harnes to get evry thing to work correctly.
good luck i found all info i needed to swap on this forum in the search box.
cheers ed
Old 02-21-2009, 11:44 AM
gearhead
There are two ways to do this on your 1974.
The easy way is to wire up your car and use the 911sc electronic speedo drive.
The hard way is to install a mechanical speedo drive on the 911sc transmission. The problem here is that the 911sc pinionshaft doesn't have an allowance for the speedo drive gear. Basically, you need to get a pinion set with the speedo drive gear(could use your '74 if it's any good). This obviously requires breaking into the "good used" gearbox you just purchased, replacing the ring and pinion, and in essence rebuilding the gearbox. Then you'll need to install the tailcone from your 1974 gearbox with the balance of the speedo drive components onto the 911sc transmission. Not very feasible for most folks.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-21-2009, 02:17 PM
