The Puff.
Mr.Puff's Avatar
Gauge power question.
Will I be OK if I run all of the gauges to the fuse box? The wiring diagrams show the speedometer going to the fuse box (Red/Black) and the rest going to the ignition switch 15 Run/Start (Red/Black also). What is the difference?
'70 CT1B
'11 GTS 300 Super
Old 02-23-2009, 01:20 AM
Happiest when Tinkering
gsmith660's Avatar
red/black is just the generic color used for power to gauges it is used for other things also to figure out which wire it is is to put power to it and see what works.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 02-23-2009, 04:24 AM
The Puff.
Mr.Puff's Avatar
Well, I know which wire it is. I just want to know if I can route them all to the fuse box. My new harness has a generic "gauge power" circuit.
Old 02-23-2009, 11:33 AM
The gauges take very little power, so a 5 amp circuit on the fusebox should be plenty.
Mark
Old 02-23-2009, 11:35 AM
gsmith660's Avatar
Make sure the wire that went to the run/start of the ign goes to the same type of power at the fuse box.
Old 02-23-2009, 11:42 AM
The Puff.
Mr.Puff's Avatar
On to the next problem. New thread: http://forums.pelicanparts.com/porsche-911-technical-forum/459089-new-wiring-harness-ignition-wiring-help.html#post4504205.
'70 CT1B
'11 GTS 300 Super
Old 02-23-2009, 11:09 PM
