Make Bruins Great Again
Por_sha911's Avatar
Replacing a Caliper question
Not the Porsche this time but the mechanics should be the same.
The wife's 380SL (which she drives like my Grandmother) has a leaking front caliper. I plan to replace it with a rebuilt one and put new pads on both sides of the front.
Is there some compelling reason to replace both calipers if only one is leaking?
Joe
Old 02-27-2009, 05:17 PM
consider it preventive maintence and even wear and tear on one set of brakes.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 05:42 PM
Por_sha911's Avatar
Granted that it is probably wiser but for time and money sake, am I OK with putting on just the one side?
Joe
Old 02-27-2009, 05:46 PM
at least exercise the old pistons and lift inside the dirt shield for fluid.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 05:55 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Not much more time and much cheaper would be to rebuild them both.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 02-27-2009, 06:07 PM
makaio's Avatar
2nd
Old 02-27-2009, 09:11 PM
efhughes3's Avatar
I'm of the opinion that brake components should be changed in pairs. Doing one side only in something like this is what kicks a vehicle's value in the a$$ over time.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-27-2009, 09:23 PM
caliper rebuild
my front caliper was sticking when I first bought my car and so i went ahead and rebuilt all four and when I took apart the rear, I found out that one of them was also seized with the pads down to 1/16th of an inch, while all other pads were like new.
I would second doing all of them if not done in a while. Brakes are one of the items you don't want failing, especially if your significant other is driving....
I am not sure how effective a simple rebuild kit will be for leaky calipers tho.. I have heard that if they leak, sommetimes it is easier to buy new calipers or have them split and completely overhauled.
Old 02-27-2009, 09:54 PM
I've rebuild a few of them on other cars that were leaking. Usually piston and cylinder needs a cleaning up. There is an inexpensive hone at parts store.
I'm a little spooked about splitting any caliper after doing a pair and one of them sucked air without leaking brake fluid. That was a fun job. I had another one drive me nuts. The caliper became air porous, again no fluid leak. That was another fun diagnosis chasing my tail.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 10:51 PM
