Make Bruins Great Again
Replacing a Caliper question
Not the Porsche this time but the mechanics should be the same.
The wife's 380SL (which she drives like my Grandmother) has a leaking front caliper. I plan to replace it with a rebuilt one and put new pads on both sides of the front. Is there some compelling reason to replace both calipers if only one is leaking?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
consider it preventive maintence and even wear and tear on one set of brakes.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Granted that it is probably wiser but for time and money sake, am I OK with putting on just the one side?
at least exercise the old pistons and lift inside the dirt shield for fluid.
SCWDP- Shock and Awe Dept
Not much more time and much cheaper would be to rebuild them both.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
I'm of the opinion that brake components should be changed in pairs. Doing one side only in something like this is what kicks a vehicle's value in the a$$ over time.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
caliper rebuild
my front caliper was sticking when I first bought my car and so i went ahead and rebuilt all four and when I took apart the rear, I found out that one of them was also seized with the pads down to 1/16th of an inch, while all other pads were like new.
I would second doing all of them if not done in a while. Brakes are one of the items you don't want failing, especially if your significant other is driving.... I am not sure how effective a simple rebuild kit will be for leaky calipers tho.. I have heard that if they leak, sommetimes it is easier to buy new calipers or have them split and completely overhauled. |
I've rebuild a few of them on other cars that were leaking. Usually piston and cylinder needs a cleaning up. There is an inexpensive hone at parts store. I'm a little spooked about splitting any caliper after doing a pair and one of them sucked air without leaking brake fluid. That was a fun job. I had another one drive me nuts. The caliper became air porous, again no fluid leak. That was another fun diagnosis chasing my tail.
