-   -   Where can I get an oil filter housing seal? (http://forums.pelicanparts.com/porsche-911-technical-forum/459649-where-can-i-get-oil-filter-housing-seal.html)
austin552 02-26-2009 01:43 PM
Didn't see any here...
E Sully 02-26-2009 02:14 PM
Try this part# 911-107-192-03-OEM
austin552 02-26-2009 08:36 PM
Thanks but I need the seal between the filter housing and oil tank.
DRACO A5OG 02-26-2009 08:45 PM
Isn't it on the filter itself?
vreference 02-26-2009 08:49 PM
Are we talking about the filter itself? If so, oil filters are typically considered consumables. I assume the easiest place to find another seal would be another filter. Just put the seal back on the new one when you are done with the current one.
Flieger 02-26-2009 09:00 PM
He means the big rubber donut thingy that the oil filter console attaches to the tank through. I need one, also. It was pinched, old, and worn out. To get it off, you must remove 3 allen head bolts behind the oil filter.
austin552 02-27-2009 05:22 AM
The filter housing has a black rubber seal that seals it to the oil tank. I need that seal.
Found one. #18
http://dcauto.gotdns.com/illustration/index/455398927
Flieger 02-27-2009 03:29 PM
Thanks for the link. #16 is what I need. :)
47silver 02-27-2009 06:59 PM
seal
i purchased one from pelican...
911-107-192-03-OEM
61 bucks
Flieger 02-28-2009 09:08 PM
Actually, upon further inspection neither #18 or #16 appear to match the part. :confused:
