Where can I get an oil filter housing seal?
Didn't see any here...
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Try this part# 911-107-192-03-OEM
Thanks but I need the seal between the filter housing and oil tank.
Member 911 Anonymous
Isn't it on the filter itself?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Are we talking about the filter itself? If so, oil filters are typically considered consumables. I assume the easiest place to find another seal would be another filter. Just put the seal back on the new one when you are done with the current one.
1989 Carrera 3.2L in 993 bodywork |
Max Sluiter
He means the big rubber donut thingy that the oil filter console attaches to the tank through. I need one, also. It was pinched, old, and worn out. To get it off, you must remove 3 allen head bolts behind the oil filter.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The filter housing has a black rubber seal that seals it to the oil tank. I need that seal.
Found one. #18 http://dcauto.gotdns.com/illustration/index/455398927
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s Last edited by austin552; 02-27-2009 at 05:31 AM.. |
Max Sluiter
Thanks for the link. #16 is what I need.
seal
i purchased one from pelican...
911-107-192-03-OEM 61 bucks
1975 911S Targa Silver Anniversary Edition |
Max Sluiter
Actually, upon further inspection neither #18 or #16 appear to match the part.
