-   -   Use later alternator in early 911? (http://forums.pelicanparts.com/porsche-911-technical-forum/459741-use-later-alternator-early-911-a.html)
KevinG 02-27-2009 05:14 AM
I am wondering if it is possible to replace my existing Bosch 55 amp alternator (dead) with one from an 84-89 Carrera. I gather that there are wiring differences due to the internal regulator, but have heard that there are ways to re-wire. Are there any other problems with making this switch? Car is a 72 911.
Thanks!
sc_rufctr 02-27-2009 05:59 AM
I installed an alternator from an 84-89 Carrera in my 78 SC.. Worked great but you're right there are wiring changes but it was so long ago I don't really remember what they were. Must have been simple because I did it on my own...lol...
I can't see any drawback or reasons not to do it. :cool:
RoninLB 02-27-2009 06:34 AM
http://forums.pelicanparts.com/uploa...1235745243.jpg
http://forums.pelicanparts.com/uploa...1235745281.jpg
ps: I didn't have to change idiot light bulb to 4 watt with Valeo alternator. Above is for Bosch alt.
304065 02-27-2009 06:36 AM
Kevin, if you search here you will find a lot of information about this. But to summarize:
1) The later alternator is longer which requires a different fan housing;
2) The later alt is internally regulated which requires a small modification to the wiring; and
3) the internal reg heat soaks from the hot engine, causing it to occasionally not work and fail after a couple years
47silver 02-27-2009 08:12 PM
alternator
went through a lot of alternators last year to find one that worked.
the depth of the alternator is critical or the fan will hit the shroud.
they look similar but there is a 1/2 inch? or so difference which will cause problems..
when you remove the old one
measure distance from tip of the shaft to the base of the alternator, there is a pic on here somewhere of the alternator differences.
RoninLB 02-27-2009 11:03 PM
I considered a marine digital external regulator if I had a cooked internal regulator problem.
Never the less I take care as best I can to prevent hot shut downs and letting it cook.
