KevinG's Avatar
Use later alternator in early 911?
I am wondering if it is possible to replace my existing Bosch 55 amp alternator (dead) with one from an 84-89 Carrera. I gather that there are wiring differences due to the internal regulator, but have heard that there are ways to re-wire. Are there any other problems with making this switch? Car is a 72 911.
Thanks!
Kevin
1972 T Targa
Old 02-27-2009, 05:14 AM
Almost Banned Once
sc_rufctr's Avatar
I installed an alternator from an 84-89 Carrera in my 78 SC.. Worked great but you're right there are wiring changes but it was so long ago I don't really remember what they were. Must have been simple because I did it on my own...lol...
I can't see any drawback or reasons not to do it.
Old 02-27-2009, 05:59 AM
ps: I didn't have to change idiot light bulb to 4 watt with Valeo alternator. Above is for Bosch alt.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 06:34 AM
304065's Avatar
Kevin, if you search here you will find a lot of information about this. But to summarize:
1) The later alternator is longer which requires a different fan housing;
2) The later alt is internally regulated which requires a small modification to the wiring; and
3) the internal reg heat soaks from the hot engine, causing it to occasionally not work and fail after a couple years
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-27-2009, 06:36 AM
47silver's Avatar
alternator
went through a lot of alternators last year to find one that worked.
the depth of the alternator is critical or the fan will hit the shroud.
they look similar but there is a 1/2 inch? or so difference which will cause problems..
when you remove the old one
measure distance from tip of the shaft to the base of the alternator, there is a pic on here somewhere of the alternator differences.
1975 911S Targa
Silver Anniversary Edition
Old 02-27-2009, 08:12 PM
I considered a marine digital external regulator if I had a cooked internal regulator problem.
Never the less I take care as best I can to prevent hot shut downs and letting it cook.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 11:03 PM
