arbita1's Avatar
83SC CO Value w/o O2 Sensor
I'm getting ready to adjust the CO setting. The Bentley manual says to use .6-.8%. However, I'm not using the O2 sensor. Should it be more like 2.5-3.0%?
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-28-2009, 10:40 AM
Scott R's Avatar
Is this a US or ROW SC? I ask because if you have the sensor unplugged, and you still have a frequency valve this is going to be an issue.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-28-2009, 11:07 AM
arbita1's Avatar
US. It has frequency valve.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-28-2009, 11:09 AM
Scott R's Avatar
Just a suggestion, of course you can go 3% route and be just fine, however I have a nice dyno sheet showing better AFR's with the sensor hooked up and the CO around .8%. Just something to consider, other wise go with the 3% and leave it disconnected.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-28-2009, 11:21 AM
mca mca is offline
mca's Avatar
Mine likes 3.0 - 3.5%
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 02-28-2009, 11:28 AM
arbita1's Avatar
Ok. I set it at .8% and hooked the O2 sensor back up. Let's see how it does.
Matt.
83 911SC
85.5 944 NA - Sold
Old 02-28-2009, 12:43 PM
