Designer King
Purpose of Points-like Connection in WUR
I have a 072 WUR (MY80) that has a breaker points-like connector attached to the metal arm, with a small adjustment screw attached. The heating element has stamped on it 2 values: 14 ohm and 26 ohm. By comparison a 045 unit for a '79 has 26 ohms only on it.
What is the function of these seemingly adjustable points? Why the 2 resistance figures?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
The second set of points inside the 072 serves to decrease the resistance of the heating element above 60 Deg F or so. This causes the heat applied to the bi-metallic spring to be applied more slowly below 60 Deg and more rapidly above. I have checked both the 072 and the 090, both for the the Lambda engines, several months ago. I don't know why the CIS engineers chose to go with this design feature.
When I first found the second set of points, my idea was that they brought the temperature up more rapidly and held it at a constant value, like an internal thermostat, but it is not wired this way...
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
Designer King
Thanks, Jim. I am currently adding this element, which I know works, to the bottom, vacuum assist, portion of a 045 WUR to make up a good WUR to use on my non lambda engine.
