Designer King
Paulporsche's Avatar
Purpose of Points-like Connection in WUR
I have a 072 WUR (MY80) that has a breaker points-like connector attached to the metal arm, with a small adjustment screw attached. The heating element has stamped on it 2 values: 14 ohm and 26 ohm. By comparison a 045 unit for a '79 has 26 ohms only on it.
What is the function of these seemingly adjustable points?
Why the 2 resistance figures?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-09-2009, 02:14 PM
Jim Williams's Avatar
The second set of points inside the 072 serves to decrease the resistance of the heating element above 60 Deg F or so. This causes the heat applied to the bi-metallic spring to be applied more slowly below 60 Deg and more rapidly above. I have checked both the 072 and the 090, both for the the Lambda engines, several months ago. I don't know why the CIS engineers chose to go with this design feature.
When I first found the second set of points, my idea was that they brought the temperature up more rapidly and held it at a constant value, like an internal thermostat, but it is not wired this way...
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 04-09-2009, 07:48 PM
Designer King
Thanks, Jim. I am currently adding this element, which I know works, to the bottom, vacuum assist, portion of a 045 WUR to make up a good WUR to use on my non lambda engine.
Paul
Old 04-10-2009, 07:29 AM
