-   -   Can an 83 Valence be replaced with an 85? Without modifications. (http://forums.pelicanparts.com/porsche-911-technical-forum/460378-can-83-valence-replaced-85-without-modifications.html)
scott2847 03-02-2009 08:58 AM
Want to replace my 83sc valence with an 85 valence. Will this work and will this bolt right on? Thanks
Super_Dave_D 03-02-2009 09:04 AM
Yes as long as you plan on replacing the fog lights as well.
scott2847 03-02-2009 09:11 AM
Thanks, I just need 85 fog lights, right? And they should just replace my old ones.
mike635 03-02-2009 10:14 AM
You may need to change the washer tank to the newer version that has a recessed area for the fog lights. I put a newer ('84 I think) valence on my '81SC and had to replace the washer tank. Found a used one and everything fit perfectly.
mike
john walker's workshop 03-02-2009 10:25 AM
the SC washer tank does interfere with the left carrera fog light body.
frankc 03-02-2009 07:20 PM
And I believe the washer pump is also attached directly to the 84+ style washer tank, rather than being mounted in the trunk.
scott2847 03-02-2009 07:37 PM
So now it sounds like I need both the washer pump and washer tank..........anything else?
TRE Cup 03-02-2009 10:41 PM
you might have to bend the horn brackets around slightly to clear the back of the passenger side fog lamp
