Tire size & air pressures
I purchased Sumitomo HTR Z II from TireRack. Sizes are 255/40-17 rear & 225/45-17 front. OEM's for my car were 215/60-15 rear & 185/70-15 front. I was curious about what pressures to run so I called. The sales guy told me the tire pressures would be the same, 29lbs. for the front and 36 lbs. for the rears cold. I guess it's my ignorance but I never thought they'd be the same pressures. I know we have excellent tire/wheel guys here so could you guys confirm this for me.
Thanks in advance.
O2 In Sully We Believe
Old 03-02-2009, 11:18 AM
djk_wff's Avatar
Wink
There are 2 things that have been etched in my mind regarding my carrera's tires: 29 and 36 mean smooth and right!
Old 03-02-2009, 11:27 AM
Bill Verburg's Avatar
I would experiment a bit if I were you, You will find a sweet spot for your car and style.
Just as an anecdotal date point, I haven't found much difference in the tp needs between 16 and 17
Bill Verburg
Old 03-02-2009, 11:32 AM
Thanks to both. I will experiment a bit as I'm planning on my first DE this summer at Lime Rock Park.
Nice arse djk
Old 03-02-2009, 11:37 AM
track pressures will be different from street.
What tires are you using?
Bill Verburg
Old 03-02-2009, 11:41 AM
Bill, The tires I mentioned above... Sumitomo HTR Z II. Sizes are 255/40-17 rear & 225/45-17 front.
Old 03-02-2009, 11:59 AM
Jupiter 911
bklyn's Avatar
Buck, just purchased the exact same tires, also from tire rack. Could not resist the price, anyway I am sticking with 29 lbs in the front and 36 lbs in the rear.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 03-02-2009, 01:44 PM
