Chain tensioner question
I'm looking to find a way to NOT use the Carrera tensioners. I can't scrap up the change for them right now and I'm in the midst of a full rebuild. The originals haven't failed and they lasted 35 years. Do the make a rebuild kit for these ('70 911T)??
THanks in Advance
Nabil
'71 S track car, 2.7L & Webers forever!
Old 09-16-2006, 10:37 AM
3.2 CAB's Avatar
Yes, or put on the collars.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-17-2006, 07:01 AM
Blanco's Avatar
Or you could go with the mechanical tensioners... but they require more maintenance.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 09-17-2006, 07:56 AM
I would rebuild the tensioners and use the collars for added safety.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-17-2006, 08:55 AM
Early_S_Man's Avatar
Porsche Crest
Nabil,
Yes, the tensioners can be rebuilt. Kits, pn# 911.105.901.01 are available from several sources, including Pelican:
CHAIN ADJ.REPAIR KIT
- This is a special-order, non-returnable, part
(availability and shipping charges may vary).
OEM-91110590101 $22.51
My suggestions are:
1. Install safety collars ASAP!
2. Install five new black and one brown chain ramp ASAP! Crumbling chain ramps can cause as much damage as a failed tensioner!
3. Acquire rebuild kits and plan on rebuilding the existing tensioners.
4. Plan on replacing your chain wheel supports [idler arms] with the 1980.5+ style, double bushing versions as funds become available. PN# 930.105.509.00 & 930.105.510.00.
When the double-bushing idler arms are installed ... you have two choices: mill off 10.0 mm from the back side of your tensioner mounts to clear the 'thicker' idler arms, or install 930.105.053.00 -- 1980.5+ tensioners. Getting your tensioners milled is not that difficult!
Good luck!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-17-2006, 09:24 AM
Thanks a million for the great heads-up fellas. I sold a '70 T coupe with a stuck motor (some friend I am) to a buddy for $3k, he's mechanically inclined but zero for Porsche experience. I've become his go-to guy for everything (he doesn't own a computer, lawn service guy). I don't mind at all as its been a great learning experience for me and its always fun to have a buddy who shares the same obsession. He got most of his motor stuff back from Olie's (I recommended them based on there reputation, and if something goes wrong with the engine its kinda on my head!) after the $4.2k bill from them (all case work, heads redone and ported and polished) and $1.3k for all the other hardware/gaskets from our host, he's getting tight!! can't blame him, so when he asked me about those I could have been lazy and said "gotta get the Carrera Tensioner" but I knew there had to be another way out! Hopefully we get it back together in time to actually drive it once or twice before it snows!! My guessis that he will be really hard pressed for motivation to bring it back to viper green and tidy up the interior this winter if all he got to do was take it apart and blow a bunch of $$'s on it!! Stay tuned, if it starts and drives soon I'll post some pics of the progress. I'll post some pics of the engine parts now that there back from Olie's, they did some really pretty work, just not cheap. I guess you get what you pay for.
Nabil
Old 09-17-2006, 08:05 PM
I rebuilt mine with the above mentioned kit. Not a simple process but I thought I got them right. They collapsed not much later. I'm glad I had the safety collars. I have spoken to others who had the same experience. I now put 930 tensioners in. Carrera tensioners have been know to fail as well.
joe
Old 09-17-2006, 08:10 PM
Kraftwerk's Avatar
Targa T,
Are the 930 tensioners 'plug and play" or did they require some "milling" as well? How are they better than the originals? thanks
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 09-17-2006, 10:26 PM
This thread is now shown on the Pelican Parts list next to 911 105 901 01-the rebuild kit for timing chain tensioners-the kit is NLA from Pelican but is available from others. Any reason not to use it? My chains have started rattling on my 82 SC.
Thanks to all for responding.
Too many cars, not enough moolah...
Old 03-04-2009, 04:45 PM
