Starting up the rebuild tomorrow--Advise?
Tomorrow I should get the last few things bolted onto my 83 SC and I should be able to test start the rebuilt motor .
Planning on 1) unplugging the CDI input to stop ignition, unplug the fuel pump relay and crank the motor over until I get some oil pressure, 2) check for leaks and fix if needed 3)plug fuel pump relay back in , crack the union to #1 injector, lift the flow plate arm to get some fuel flow and purge the fuel system of all the air I've introduced until i get some fuel at #1 3) plug in the CDI and see if she'll fire up
Of course before I do any of this I'll double and triple check all the fittings and bolts.
Any other first time on a new motor hints?
'83 SC Coupe
Old 03-16-2009, 02:56 PM
mca mca is offline
mca's Avatar
Great! Exciting times ahead.
Make sure dizzy isn't installed 180 deg out.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 03-16-2009, 03:00 PM
Less brakes, more gas!
euro911sc's Avatar
Don't forget the oil
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-16-2009, 06:26 PM
Wer bremst verliert
JohnJL's Avatar
Keep a fire extinguisher handy.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-16-2009, 06:36 PM
keep us posted and take a lot of pictures for us...
Craig
Old 03-16-2009, 07:12 PM
DW SD's Avatar
triple check firing order. build oil pressure with the plugs out.
1971 RSR - interpretation
Old 03-16-2009, 10:34 PM
DW SD's Avatar
Is radio silence here a bad sign?
Hope not,
Doug
Old 03-17-2009, 04:55 PM
Brother's Avatar
Do you need to worry about the charge of the battery with all the cranking going on without starting?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 03-17-2009, 05:22 PM
diy83sc's Avatar
Congrats in advance! Have a bottle of champagne or your favorite beverage on hand. You will be happy you did it yourself. I rebuilt my engine a few years ago over a cold winter. Almost 15,000 miles later, many of them at the track, it is still running like it did 20 minutes after rebuild
Old 03-17-2009, 07:10 PM
