Todd Simpson's Avatar
What removes OLD brake dust?
Caked on, been there 10 years, brake dust on the inside of wheels...Any tips?
Old 03-07-2009, 06:57 PM
rsrfan's Avatar
Just cleaned up a set of Kinesis rims for the installation of new tires and balancing. Used a couple of SOS pads with great results.
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 03-07-2009, 07:14 PM
I used P21S wheel cleaner with a nylon scouring pad. Took a couple of applications but I was happy with the result.
Old 03-08-2009, 06:31 AM
Almost Banned Once
sc_rufctr's Avatar
Please be careful with my suggested method...
If you have an original factory finish on the wheels you could use acrylic thinners to get the old dust off... Test in on a small area first and if OK go for it. (The finish is usually thinner on the inside of the wheel)
But if they have been refinished by either a pro or the previous owner don't even think about using acrylic thinners.
Old 03-08-2009, 06:43 AM
M491Cabriolet's Avatar
I have been pleasantly surprised at how very well the Professional Wheel Cleaner spray from Advance Auto Parts works. It, so far, is the best product I've found out there to clean up brake dust. On stubborn areas, I use a simple wheel brush with this product and the results are excellent. It's fast and very efficient. I'd give it try before scouring, which may be a bit harsh on your wheels' finish.
Old 03-08-2009, 06:45 AM
I use P21S wheel cleaner--one component of an excellent set of German cleaners, polishes and other auto-car products. I'm sure Pelican carries them.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-08-2009, 07:39 AM
Ditto on the P21S. It's very gentle on old finishes. But it's important to be patient, it doesn't all come off immediately.
Chris
Last edited by chrisg252; 03-08-2009 at 08:09 AM.. Reason: Hit the enter button by accident before I completed the post.
Old 03-08-2009, 08:02 AM
Less brakes, more gas!
euro911sc's Avatar
Elbow grease There is no substitute...
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-08-2009, 11:21 AM
Somatic Negative Optimist
Gunter's Avatar
Be sure that any harsch cleaner doesn't reach the front finnish; it could leave streaks on paint and anodizing.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-08-2009, 11:55 AM
175K911's Avatar
-Michael
I've used my pressure washer, turned down to about 1400 psi, using P21 in the suction cup of the pressure washer. Have to be very careful not to blast the finish off the wheels but done carefully it works
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-08-2009, 12:02 PM
m110's Avatar
I would remove the wheels so they can be flat and everything doesn't just slide off. P21S in gel form is my preference. Spray on dry so everything is coated at 100% cleaner concentration (water before just dilutes it). And as previously noted by kiwioki a nylon scouring pad for some mechanical action. You may have to repeat a few times. There are faster ways with some harsher chemicals like acrylic thinner but I think this is the best bet if you're concerned with the finish (especially anodized). You didn't mention the finish on the wheels as that has some bearing on how aggressive you can be.
1988 Carrera Coupe
Old 03-08-2009, 03:37 PM
thanks for the suggestions....the wheels are going to be refinished anyway so I can afford to be brutal. In fact on the front I have to go to 200 grit just to get the brake dust pitting out. These are old BBS style 2 piece wheels.
I like the gel idea...most of the sprays seem to evaporate after a minute or two.
Then lots of elbow grease...
Old 03-08-2009, 04:01 PM
ruf-porsche's Avatar
Wear a mask, brake dust can cause cancer.
Old 03-08-2009, 07:54 PM
AutoBahned
RWebb's Avatar
won't hurt - but that is based on asbestos in brakes, which was outlawed some years ago, maybe decades ago
Old 03-08-2009, 08:00 PM
