Goth's Avatar
Question Pulley Bolt Torque Spec ?
Just replaced the front seal (fan pulley side of crank) on my 3.2.
I did a few searches and can't seem to find the tightening torque spec for the bolt that holds the pulley onto the crankshaft.
Anybody know what it is?
Thanks!
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 03-10-2009, 01:18 PM
Band.
From Wayne's engine book:
Without A/C (use spring washer underneath) 59 Ft/lbs.
With A/C (no spring washer) 125.3 Ft/lbs.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-10-2009, 01:59 PM
Peter Zimmermann's Avatar
Doug: If you have a bolt that uses a spring (wavy) type lock washer the torque is 80Nm (58 lb/ft). If you have a Durlok bolt the torque is 170 Nm (123 lb/ft).
Keep the Shiny Side UP!
Pete Z.
Old 03-10-2009, 02:03 PM
Goth's Avatar
Thanks a lot guys. I really appreciate the help.
Take Care...
Doug
Old 03-10-2009, 02:08 PM
