-   -   Simplify your intake system: one 4 barrel! (http://forums.pelicanparts.com/porsche-911-technical-forum/462361-simplify-your-intake-system-one-4-barrel.html)
techweenie 03-11-2009 10:46 PM
Found this on CraigsList:
http://sandiego.craigslist.org/nsd/pts/1064849266.html
sc_rufctr 03-11-2009 11:03 PM
That is awesome... Would be something to play around with a set-up like that.
I bet it would go hard... But it doesn't look right for a 911 engine bay so that would be reason enough for some people to bag the idea.
Good find :cool:
sc_rufctr 03-11-2009 11:04 PM
It's worth $200 for the intake pipes alone... I love the custom CIS box base :cool:
techweenie 03-11-2009 11:23 PM
I saw one of these setups years ago, but this one is a bit better developed.
James Brown 03-12-2009 01:09 AM
I think that carb would ice up if you don't heat up the plenum and the tubes
911pcars 03-12-2009 01:20 AM
Due to the distance from the accelerator pump, the engine might experience turbo lag, but without the turbo.
Sherwood
James Brown 03-12-2009 02:26 AM
kinda cool, and cheap!!!
Porsche-O-Phile 03-12-2009 02:36 AM
Tempting... I wonder about putting that on my 2.7... Hmmm. A heck of a lot cheaper than either Webers or (yikes!) PMOs. Ya know what "PMO" stands for right? "Pay More Out". :)
I have a spare CIS box downstairs. That's giving me some ideas... Surprised more people don't try stuff like this. Seems almost idiotically simple and bulletproof.
matty74 03-12-2009 03:09 AM
that is a damn good idea
Rob B 03-12-2009 03:54 AM
Reversing technology, just like NASCAR. There are lots of reasons not to.
Rob
berettafan 03-12-2009 05:29 AM
the neat thing about it isn't the cost savings but rather the need to only tune one mixture, etc.
not to mention a sniffer machine at the tail pipe would actually mean something!
sc_rufctr 03-12-2009 05:32 AM
All good comments but how would it perform?
Has anybody used a similar setup?
berettafan 03-12-2009 05:37 AM
Doesn't CIS have a common plenum?
stormmaster 03-12-2009 06:34 AM
I had a single carb on my 914 years ago.....it ran fantastic and no more issue with Fuel Injection.
SpeedracerIndy 03-12-2009 06:40 AM
Bob Farmer (Farmer's Automotive), here in Indy fabricates a setup just like that. I have seen it on one of his race cars in the shop. He said it flows better than the common setups, and it is cheaper and easier to tune. I wish I had taken a picture when I was in there a few weeks ago getting my mixture adjusted. Someone in the local area has to have experience with it.
bkreigsr 03-12-2009 07:18 AM
the guy in the booth next to me at Hershey last year had one FS & I got to talk to him about it.
Yes on the turbo lag, with lots of gas fumes in the cabin when driving, and he could not get jets small enough to lean it out for sub 3,000 rpm driving.
He started out at $250 at 6:30am and was at $25 by 3:30pm with no takers.
The carb alone is over $400 new isn't it?
Bill K
911pcars 03-12-2009 11:39 AM
I think that might work okay at a constant throttle opening. As for overall operation, I have my doubts. How does each cylinder receive an equal amount of A/F? Thank you.
40 years ago, someone (EMPI?) manufactured a single 4-barrel carb. conversion for the Corvair and it didn't work as well as the factory setup of two single barrel carbs feeding each bank of three cylinders. Summarize what you will out of that bit of history.
But time marches forward, and I'm not against any attempts at improvement.
Sherwood
Quicksilver 03-12-2009 12:26 PM
BZZZZZZT... thankyouforplaying...
Holly's are easy to tune, produce good power, come in almost any size, are great for muscle cars, ...
...and suck for dealing with g forces. You can easily set it up for acceleration forces but dealing with forces from all directions will cause float level problems.
In practice what you get is: A good sticky set of tires and the engine will tend to flood under hard braking as gas sloshes from the vent tubes into the venturis. To get the lateral acceleration problems under control you have to lower the float level but that causes the jets to tend to uncover from sloshing. The core problem is the float chamber isn't very tall and is rather wide. This doesn't work for hard cornering and braking.
Bill K
The jet sizing isn't really a problem if you really know how to tune the whole circuit system in the Holly. What he needed to do was drill out the corresponding air bleed to reduce the signal to the jet. Changing the emulsion tubes might be enough to solve this too but they aren't made to be removable. To do this you need to be willing to sacrifice a few carburetors to get it right.
When you are done messing with it you will end up with a system that cruises great but the float system still won't let you corner or brake.
RWebb 03-12-2009 12:42 PM
I did that on a bus motor in the 1970s. It works but not nearly as well as some other options.
And... it has been discussed here before.
In essence, it has the advantage of being cheaper than some other options, but that is about it.
What I like is the cheapo m/c throttle body adaptations that some were playing with. We all know that there are LOTS of wrecked m/c's lying around.
jluetjen 03-12-2009 01:55 PM
If you want an affordable alternative to Webers or PMOs -- get some Zeniths. While they don't have quite as many tuning options as Webers, I'd have to believe that they are certainly better then the Holley in this application given that they were original equipment 911T's for a couple of years.
rouxroux 03-12-2009 03:41 PM
I've used setups like this before on Corvair engines (IECO made them), both on the 2 carb and 4 carb engines. The only problem I ever had was getting sufficient carb heat in the winter. Sure was alot easier than rebuilding/synching 4 Rochesters!;)
EarlyPorsche 03-12-2009 03:44 PM
You guys forget that a holley has a CHOKE. Chokes are needed on daily driven cars for sure.
James Brown 03-12-2009 05:04 PM
what do you guys think of two weber 2 bbl's on that set up. should fix the float problem and look kinda cool?
TRE Cup 03-12-2009 05:28 PM
go drive that thing at night or during a cool day- you can refrigerate anything attached to the intake below the carb= it ices up
same issue with the corvair single 4 bbl conversion- left us sitting by the side of the road till the tubes warmed up
bad idea
jluetjen 03-12-2009 05:39 PM
... or how about a Rochester TBI injection system off of a Chevy Luv pick-up truck! No wait, with a little bit of work you could put on a Solex updraft carb from a Maserati race car, or better yet how about a set of 6 Stromburg side-drafts from a Jag? SU/Hitachi's off of a 240Z?
And then there are those really cool floatless carbs from Solex. Oh yeah -- Porsche tried those, and they didn't work as well as the Webers or Zeniths.
Formerly Steve Wilkinson 03-12-2009 05:40 PM
Why do you think chokes are needed "for sure" on daily drivers? I have PMOs--no chokes--on a car I use all year round except when it snows, and the correct accelerator-pump use makes starts reasonably easy, first of the day. (And thereafter, starting is absolutely normal.) In fact my daughter is better at starting it than I am; she can usually catch it on the first attempt.
I'm not saying it's anything like as easy as a modern FI car, but I wouldn't discourage somebody from trying to drive a chokeless car. It's an urban myth that they require chokes, just like it's an urban myth that carbs require constant tuning.
Dixie 03-12-2009 06:10 PM
As you stated.... "BBBZzzzz..... Thanks for playing." For a Holley equipped car turning corners, you simply need a Holley with center-hung floats, and extended jet tubes.
What the heck do you think Trans-Am cars ran in the '60s? What do you think NASCAR runs today?
RarlyL8 03-12-2009 06:36 PM
I used to have a '73 Widebody hooliganmobile with 40mm Weber and Supertraps. That was the quickest revving coolest sounding car I ever owned. On a 20* day it would fire up and sound like an Indy car as I pumped the trottle as fast as I could to keep it running until it warmed up.
And now for something completely different ...
http://forums.pelicanparts.com/uploa...1236908162.jpg
James Brown 03-12-2009 07:36 PM
is that a 2bbl holey?
James Brown 03-12-2009 07:46 PM
hear is a holley for NASCAR with +- 3g capability of supplying fuel at any angle
http://forums.pelicanparts.com/uploa...1236912271.jpg
850 CFM might be a little big but for $1200 bucks, it's yours!!!!!!!!!
sc_rufctr 03-12-2009 07:56 PM
Back in the day when I owned an air cooled beetle it was common practice to disable the choke.
The idea was if it got stuck open the extra fuel would wash away the oil from the cylinder walls. The theory was this lead to reduced engine life but that was a subject of much debate for a long time...
Thinking back it was never really hard to get the car started. Two pumps of the gas peddle and then turn the key. As soon as it fired you then press part throttle to keep it idling. You had to idle it that way for about 3 minutes and then you were good to go. :)
911pcars 03-12-2009 08:40 PM
What do you guys think of one throttle bore per cylinder (total of six)? Each throttle bore delivers the same amount of air/fuel to each cylinder; Such an animal could incorporate three throttle bores in one housing with a shared throttle shaft so throttle movements remain in sync; install the multiple throttle bore assy. directly over each intake port on the bank for good throttle response. Each throttle bore has its own accelerator pump. And to make it even more exciting, provide a wide range of removable air bleeds, emulsion tubes, fuel jets and venturis to fine tune the fuel delivery for a wide variety of engine displacements and operating conditions.
I'd pay money to have a carb. setup like that. Maybe Holly will make one for us. :rolleyes:
Improvements are welcome, but sometimes re-inventing the wheel isn't necessary.
Sherwood
James Brown 03-12-2009 09:07 PM
your talking PMO's! full circle
911pcars 03-13-2009 12:31 AM
Existing Webers and PMOs. Yes.
Sherwood
Quicksilver 03-13-2009 01:55 AM
I wouldn't exactly call that a Holly. I would call that a huge bag of tricks that started out as a Holly. They can be made to work but open up the wallet. The core problems are that the width of the float chamber must be dealt with and the vent location must be worked around..
BTW - That carb won't work 3 Gs in any direction. It can be made to work well at 3 Gs in one direction: left or right. Under hard braking it won't work well on race cars but they don't care. They don't care about mixture problems under braking as that only causes burbles and backfires. Besides every other car on the track has the same carburetor mandated by the rules so who cares? If NASCAR allowed any type of injection how many cars do you think would have carbs?
I have actually built Holly racing carburetors. I still have some in the garage. (The 390cfm setup for the 3.5 liter Olds would probably work pretty good for the craigslist manifold.) Setting them up for road racing was work. Getting them to work on a road course with race tires was irritating.
Here are a few tricks to pull out of the bag...
- If it has side feed floatbowls (like the craigslist ad) replace them with center hung floats. (as pictured above)
- Put in the plastic internal vent extensions to reduce fuel sloshing out the vents. (Most of the performance Hollys with center feed floats have them from the factory since the early 80s)
- If the engine is flooding under braking because of fuel sloshing out of the secondary vent you can connect the 2 float vents with a loop of rubber tube with some small slits at the very top. That will let the fuel slosh into the other float bowl.
- Soldering extension tubes into the jets is a given. For a circle track application the tubes can actually be angled towards the right side of the float chamber.
- In extreme cases try movable jet pickups made with model airplane fuel hose and drilled out model airplane "clunker pickups".
- Replace the brass floats with foam floats that can be trimmed to deal with the specifics of the fuel control problem.
I could get the craiglist thing to work fairly good with some work and parts that I have on the shelf in the garage but I don't feel a need to punish myself.
Basically the real world solution to the problems involved is to get a copy of Stock Car Magazine and call a few carb builders from the ads in the back to get a carb that has seriously been gone through. Once you have that ($$$) starting point you can then start tuning it to the engine.
Or you can go with a bolt on solution that is known to work. PMOs, CSI, MFI, or my favorite hot rod solution: Megasquirt.
Quicksilver 03-13-2009 02:03 AM
I learned to heel-toe by driving a car with no choke during winter in Alaska. I didn't know it was a 'technique'. I was just trying to keep the stupid thing from dieing.
It really helped out later when I learned there was more to driving then aiming the car...
kidrock 03-13-2009 04:02 AM
Way back in the day, Holley made a 2bbl carb for VW called the "Bug Spray". Actually a very decent carb and juiced up my Bugs and Buses very nicely.
I realize that I'm comparing apples and oranges here...but it seems the general consensus on this thread is that the 4bbl has many disadvantages for an air-cooled flat six.
Maybe there is a more suitable 2bbl out there? Maybe someone has experimented with one and can share their experience?
Aurel 03-13-2009 04:12 AM
Maybe a modification of the fan shroud to cover the intake pipes would allow such a setup to work...
911pcars 03-13-2009 10:09 AM
My Camaro buddy sent me this regarding the Holley 4-barrel carbs:
"I installed a Barry Grant Mighty Demon to replace my Holley Double Pumper.
More adjustments such as replacable idle air bleeds, idle feed restrictors, high speed air bleeds, and annular fuel boosters instead of dog leg boosters in the holley. All this means is you can fine tune the Demon to a higher level for much less money than a Holley. The demon annular booster fuel dispersion at low to midrange rpm is awsome. Much better low end response than the holley. The Demon copied all of the Holley's strong points and then made it better for a lot less money."
FWIW.
Sherwood
RWebb 03-13-2009 11:32 AM
Sherwood
contender for best post of '09!
