-   -   MSD - 83 SC Question (http://forums.pelicanparts.com/porsche-911-technical-forum/462522-msd-83-sc-question.html)
brads911sc 03-12-2009 06:31 PM
I have an 83 SC with the PermaTune. Switching it out for the MSD 6200 and Blaster Coil... Which Tach adaptor do I need? 8910 or 8910 EIS?
Thanks in Advance
Brad
83 SC
PeteT 03-12-2009 08:24 PM
Brad-I have an sc also and didn't need a tach adapter. Works fine no problem. Good luck
Pete
Porsche 2 03-12-2009 08:29 PM
Also, I recommend you use 8.5 mm Magnocre or equivalent plug wires, and open up the plug gaps per MSD suggestions.
dlagerstrom 03-12-2009 08:41 PM
Me too. '82 with permatune that quit. Replaced with 6200 and high-vibration blaster coil. Tach works great as is.
brads911sc 03-13-2009 04:11 AM
Great. Thanks.
I have the braided stainless beru wires. will they not be able to handle the MDS?
Formerly Steve Wilkinson 03-13-2009 07:20 AM
I think it's not whether the Beru wires will handle the MSD as it is that the Beru connectors are terrible. I went to twin MSDs, twin Blasters and 8.5 Magnecor wires, at the suggestion (demand?) of Steve Weiner, also on an '83 SC (twin-plugged, also by Herr Weiner). Didn't need a tach adapter either.
Vipergrün 03-13-2009 07:56 AM
Another cool trick is to use spade connectors (with a bit of dialectic grease) to connect the MSD to the OEM harness connector. No need to splice. No tach adapter needed on my 80SC. Used Magnecor wires, plugs gapped to .045.
