Southern Class & Sass
Dixie's Avatar
Stripped guide tube screws
Any thoughts on the best way to remove stripped guide-tube screws? See this thread for details.)
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-01-2008, 04:27 PM
Zeke's Avatar
Are they frozen or spinning? Spinning to me is "stripped." If that's the case, I'd grab the tube with something that would put a good pull on it and then remove the screws a little on one side then the other. Frozen would call for heat and an impact screwdriver. Or is it the heads of the screws, you don't say. That, too, would be solved with an impact driver, the kind linked to on the other thread.
I'd heli-coil the holes once you get them out.
Old 04-01-2008, 04:36 PM
Dixie's Avatar
They're frozen. And there's not much left for the screw driver bit to engage...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-01-2008, 04:40 PM
drill until the head pops off, or a hammer and a sharp punch to dig in on the edge and tap in the loosening direction.
206 637 4071
Old 04-01-2008, 04:44 PM
burgermeister's Avatar
A manual, hit-it-with-a-hammer impact screwdriver works magic on phillips screws. I used to have a Honda 450 back in my pre-family days, and without an impact most screws (and almost everything used screws) were impossible to remove. Even works when the recess has been buggered up quite a bit.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 04-01-2008, 06:32 PM
Should there be any threadlocker in the guide tube bolts? I was thinking the low/medium strength may be recommended.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-12-2009, 08:17 PM
Heat them (pretty hot) with a torch. Make a simple shield (a piece of metal with a hole in it) to avoid overheating the surrounding case. After they cool remove them with an impact driver; the kind you whack with a hammer, not an impact gun. These, by the way, work best with a measured blow from a heavy hammer rather than a harder hit with a light one.
regards,
Phil
Old 03-12-2009, 08:39 PM
I need to clarify, I have mine guide tube and and wondered if it is suggested to use some sort of threadlocker on reinstallation. I used JW's method and just drilled the old bolts till they weakened. One thing I noticed was that once they got pretty thin you could put the drill on reverse and they'd back out very easily.
Buck
'88 Coupe, '87 Cab,
Old 03-13-2009, 11:11 AM
