boogie_man
Decel Valve--vacuum limiter--install
Hi, I'm new to the board as I just purchased a very clean 1982 911SC Coupe. Upon going over it with the seller, he advised the decel valve was confirmed to be on it's way out (high idle when coming to a stop with clutch in, then slowly winds down). I was wondering if they're avail and the ease of install. Any input would be great and thanks for having me....this is my 2nd 911 (10 years ago 79 SC Targa).
Scott
"By the time they got to Le Mans, all was said and done"
Old 03-14-2009, 03:25 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Most people would say that the decel valve is not completely necessary. You can remove it and plug the lines and the car will run fine.
I happen to like the what it does. It makes rev matching easier by causing the engine to hang a bit when letting off the gas.
There are versions that are adjustable. Mine is, and I believe the earlier ones from 78-79 are on USA models. If yours is shaped sort of like a bell with a vacuum line coming out of the top, it is adjustable. Take off the vacuum line and unscrew the nipple to shorten the amount of time the engine hangs.
1981 SC ROW Coupe
Old 03-14-2009, 04:40 PM
boogie_man
Hey thanks for the reply...any links or photos to make sure what/where I'm dealing with this ??? Might blocking it off to see if that's the fix. Or should I just put a new one on ?? Easy to get to ??? Again thanks
Old 03-14-2009, 06:34 PM
Band.
Scott,
Once you find the decel valve: If it's hooked up, just pull the vacuum line off and plug the line with a golf tee, or a small pencil, or something. Then, see if your problem clears up. As already mentioned, many people unhook the decel valve on purpose.
If plugging the line works for you, make sure to take the line out and plug it with a vacuum plug where it meets the airbox.
On my '83, the decel valve is on the passenger side of the engine, slightly higher than the valve cover, towards the front of the engine. And yes, its unhooked.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-15-2009, 12:19 AM
kodioneill's Avatar
The idle on my 82sc hung up also. it was the weights in the distributor hanging up. just another place for you to look in case it's not the valve.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-15-2009, 06:26 AM
Jim Williams's Avatar
On your '82, the decel valve will be located in the area behind the fuel distributor (towards the front of the car). The Aux Air Valve and the Decel Valve will look similar, both being saucer shaped. The Decel Valve will be the one with three hoses, one small line and 2 larger ones. The line which controls the opening and closing of the diaphragm is the small one. Plug it and see what effect this has on the high idle.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 03-15-2009, 06:41 AM
arbita1's Avatar
Could you explain this one a bit more.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-15-2009, 06:45 AM
kodioneill's Avatar
my idle would hang above 1000 for a long time after warm up. i check all the warm up control components and everything was good. so i pulled my distributor and took it apart. the inside was covered with dirt and crap. cleaned everything assembled it and now it runs like a dream. search "sc dizzy" you'll find many posts on this, and some neat pics of the dis assembly process.
1982 chiffon 911sc
Old 03-15-2009, 06:53 AM
boogie_man
Golf tees are amazing !! LOL. it worked idles like a champ. Do i need to plug the top of the saucer at the nipple ?? Thanks for the advise.
Old 03-15-2009, 09:01 AM
Band.
NIce! Don't think you need to plug the 'saucer', but remove the vacuum line and plug the nipple you expose on the airbox when you remove the line.
If you have an extra vacuum plug, probably won't hurt to put it on the nipple on the "saucer" as well, just in case, to keep it from getting all dirty.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 03-15-2009, 09:14 AM
