How does one lower the IDLE on a 1970 911E
HI,
I have a 1966 912 with a 911E engine. The idle seems pretty high at approx 2000 RPM's. Is there an easy way to lower this? Where should it be?
Any advice is appreciated...
Old 03-15-2009, 01:04 PM
haycait911's Avatar
carbs? MFI? regardless, first disconnect the throttle actuator at the manifold to make sure it's not a linkage issue. then set idle, then connect linkage.
Old 03-15-2009, 01:29 PM
Zeke's Avatar
Yes, you do have to tell us if that is an MFI car. All 911E's started out as fuel injected cars. If yours still has the injection, there are several possibilities for the high idle. You can start reading about troubleshooting here:
http://www.pelicanparts.com/techarticles/911_MFI/TipMFI.htm
Pay particular attention to the "Check, Measure, Adjust in the 2nd "Documents" section.
Old 03-15-2009, 04:18 PM
how high is it?
206 637 4071
Old 03-15-2009, 04:37 PM
HI,
It is a 1970 911 E engine, it has a (I believe) 1974 K-Jtronic fuel injection added to it...it idles around 2000 RPM...
Old 03-15-2009, 09:43 PM
haycait911's Avatar
how about an engine number and a couple of pics? that's an odd combo, to say the least.
Old 03-15-2009, 10:51 PM
Yes, it is an odd combo...6202184...CIS
Old 03-15-2009, 10:57 PM
haycait911's Avatar
other than working thru the usual CIS tuning/trouble-shooting. could it be an injection system designed for a 2.7 just not working well on a 2.0? is it a recent conversion?
if it was working fine previously, the CIS tuning/diagnostic should do it.
Old 03-15-2009, 11:04 PM
no..it was working fine...I remember seeing my mechanic turn a knob in back of the air-box and lowered the rpm's very easily...does this sound right?
Old 03-15-2009, 11:09 PM
pwd72s's Avatar
i'M WONDERING...COULD THIS BE A 912E engine???? 4 cylinders or 6?
Old 03-15-2009, 11:16 PM
6 cylinders, it has an airbox, it is not carburated, it is fuel injection, CIS.
Old 03-15-2009, 11:29 PM
after thinking...is there a knob that adjusts the throttle? This would raise / lower the idle, right?
Old 03-16-2009, 08:09 AM
(the shotguns)
berettafan's Avatar
points adjusted lately?
Old 03-16-2009, 08:45 AM
JB JB is offline
Yes, the knob on the left side of the throttle body is an air bleed past the butterfly. Screw it in some and the idle should drop.
Old 03-16-2009, 08:50 AM
if the knob bottoms out and the idle is still high, maybe the auxilliary air regulator is not getting 12V in order to close off. ( then the warmup regulator wouldn't get it either). pop the black plug off and check with a test light. another thing that causes high idle is a rotted out brake vacuum hose down where it attaches to a tube in front of the rear torsion bar tube. clamp off the hose up in the engine area and see if the idle drops. left side near #3 intake runner.
206 637 4071
Old 03-16-2009, 10:15 AM
(the shotguns)
berettafan's Avatar
but start with timing/points. no sense getting the fuel/air right if spark isn't.
Old 03-16-2009, 10:42 AM
Thank-You for all your help, tightened the screw almost to max, and it lowered the idle a bit...but, I am sure I should have mentioned this earlier (or maybe it does not matter)...the car has an MSD Blaster Coil and MSD Ignition...
Old 03-16-2009, 08:48 PM
Wer bremst verliert
JohnJL's Avatar
If it was working fine then started idling high all of a sudden I'd check for any vacuum leaks.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-16-2009, 09:27 PM
signature65's Avatar
Vacuum retard on the distributor come off?
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 03-17-2009, 09:49 AM
jluetjen's Avatar
Could you post a picture of your engine? Putting CIS on that engine is about as strange as putting a 4bbl on it. Given the overlap on the cams, I'd be curious if you could get the idle down to 1000 RPM or less and keep it even. With it idling at 2000 RPM, it must be tough on first gear synchros!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-17-2009, 02:04 PM
