What would cause a "light" pedal feel on a 915?
This car (an '84 911), has a very light feel to the clutch pedal compared to other 911s I've driven and my 1980. A tired cable? Broken or cracked omega spring? Also, the clutch engages closer to the floor than on my car. Adjustment? My search for "light pedal" didn't turn up what I was looking for and I thought I'd ask before I dive in...
Kurt |
maybe it has a new clutch. that's they way they feel.
Yep, that's the way they're supposed to "feel." A proper clutch replacement, along with a new factory o.e. cable, delivers great comfort. It's much easier to do this work wrong than right...
Keep the Shiny Side UP! Pete Z. |
John and Peter,
Thank you both for the replies. I just did another search using some different key words and found Peter Zs comment about a new clutch and a "comfortable" pedal feel. I forgot to add that the car does have a recent clutch replacement and shifts smoothly in all gears, just seems to grab lower than my 1980 (which is about halfway along its pedal travel). Where should the clutch engage, low, middle, high up? Is the SC engaging too high? Thanks again...
Kurt Last edited by KNS; 04-30-2009 at 11:14 AM.. |
engagement point should be somewhere that is comfortable for the individual and allow for a smooth shift. too close to the floor and the clutch may not disengage completely and cause hard shifting.
Less brakes, more gas!
You can adjust the pedal height, no? By using the two nuts on the cable that hold it to the tranny. Just make sure to adjust the screw and lever arm to spec.
-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
http://forums.rennlist.com/rennforums/911-forum/444690-as-promised.html?highlight=clutch+cable+installation
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 04-30-2009 at 01:15 PM.. |
Thanks again and thank you for the link... more investigating to do.
Kurt |
Ahhh. I always adjusted the bolt to get the .2 mm...
-Michael
If it was quite recent/low miles, you might want to check that the new clutch didn't just bed down and eat all the free play adjustment.
My pedal got a lot lighter and the engagement point moved down towards the floorboards when that happened - it wasn't free to clamp down fully on the flywheel either.
'77 S with '78 930 power and a few other things. |
I checked under the floor board and found that the clutch stop was loose and had settled into a "high" setting. I moved it about 1/4" to 3/8" for further pedal travel and that improved where the clutch "seems" to engage. Clutch was replaced in at least the last few hundred miles, maybe more (I'll have to check the mileage).
Also, the clutch pedal (the part you put your foot onto) does not sit even and parallel with the brake pedal. However, you can pull it back towards you with your fingers for about a 3/4" for them to line up even. Is this an issue? Just to reiterate, this is the smoothest 915 I've ever shifted.
Kurt Last edited by KNS; 04-30-2009 at 08:18 PM.. |
