LinkBack | Thread Tools | Rate Thread |
rear wheel jumping bad when trying to let clutch out from standing stop
just started to hapen all of the sudden. when stopped i can't get smooth clutch enguage meant when trying to get the car moving. car is 1983 930 and the clutch cable and pedal cluster bushing were replaced 3 months ago. engine was replaced as was the clutch and t/o bearing. just got it out of the shop- replaced torsion bar, bushings, and shocks front and rear. took it to get corner balanced and 4 wheel alignment and it started doing this on the way home. once the car is moving there are no problems just standing starts. i had a friend of mine try to get it moving as i watched and the rear wheel was hopping all over the place violently. any help would be greatly appreciated.
transmission and engine mounts for sure.
cheap and easy repair.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Try mounts at first. If not you might have a bad clutch or damaged flywheel.
Schleprock
Check the shock absorber on the bouncing wheel.
Kevin L '86 Carrera "Larry" |
abit off center
Did they surface the flywheel when they put the clutch in it?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
my 82 did the exact same thing it was so bad it would stall.
look at your mounts if they look collapsed as in the diagram they need replacing. if your over 100k miles they're bad.
Just out of the alignment shop and it started suddenly? I'd be looking at all the bolts involved as well as the mounts. If anything is found to be loose on the spring plates, you will need it re balanced (for free, of course!).
GFCC
Since you just had your clutch cable replaced, make sure your Bowden tube is adjusted correctly. If not it will cause a very violent shake from the rear at take off.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
guys, thanks for all the info. i will have them look at all the suggestions you made. this thing has given me more ups and downs. i was so physched to to the suspension work done and the car ran great now this. hopefully it's one of the easy things. thanks again. mick
I had same symptom, -- it was the Boden tube. Make sure it is not close to any item along its length, --adjustment can move it clear of any item.
see if all 4 engine to trans nuts are tight. uneven tightening of the 9 pressure plate bolts can damage the p plate. i've had that problem using a spring disc in a 930. switched to rubber hub and it was smooth. motor mounts, bowdern tube adjustment or just an old dragging clutch cable can do it. whatever, take it back and have the shop deal with it.
had a new clutch cable installed when the engine was swapped(3 months ago and maybe 1000 miles). the shop said it would stretch and need to be readjusted. could this cause it to shutter that bad on intial take off? it shift fine and behaves normally once rolling(no noises, grinding, or slippage). the weird thing is it just started to do this after all this suspension work was done. maybe just coincidence? will tell them to check trns mount and engine bolts.
is it a porsche shop?
i had/have the same thing. i readjusted the clutch and it hepled, i think mine is still out of whack, my clutch arm hits on the heater box and will not return all the way. the clucth is very tricky to adjust.
found nut on clutch cable back off and was loose. tightened and readjusted now everything is back to normal. thanks for all your help as it was much apprerciated.
there are two adjustments for the clutch. there needs to be a small amount of clearance between the short arm and the bolt through the long arm (about 1mm) and the two nuts on the bowden tube are then adjusted to get a comfortable engagement point of the pedal.
