911 identification help?
Hello all,
Need a bit of help. I have run into a 1975 911 that I am interested in buying but need some help identifying the original specs of the car.
The Car appears to be a Carrera. It is advertised and labeled as such, and owner claims it is an original Carrera. It has the wider (original as far as I can tell) fenders, spoiler, whale tail, etc. The car has a bit of work and upgrades done to it like the large oil cooler, 16x7/8 wheels, Weber carbs, headers, and a few others.
But here's my issue, the vin number starts with 911520xxxx, which according to my research is for a US 911S Coupe.
My question is on the authenticity of the Carrera labeling. Was there such a thing as a Carrera option for the 911S? and it it possible to have an actual real 1975 Carrera with a vin number that identifies it as an S? or can I assume this is a 911 S that someone at some point converted to a Carrera?
I'm not too familiar with the older 911s so any help of info would be greatly appreciated. I should also mention this is a US vehicle.
Cheers,
Jose M.V.
Old 03-17-2009, 08:52 PM
Regis turd ab user
You are correct on your numbers and assumptions.
The Carrera is a seperate model with #'s 9115400001-9115400395 US coupes, 9115410001-9115410174 US Targa.
ROW(rest of world) Carrera 9115600001-9115600518 coupe, 9115610001-9115610197 Targa.
The US Carrera and the 911S have the same motor the ROW Carrera motors are much different .
Old 03-17-2009, 09:28 PM
Thanks for the info. That`s what I though, and although disappointed it's not a Carrera it should give me some negotiation leverage.
How much different are the ROW Carrera engines from the US versions?
Cheers,
Jose
Old 03-18-2009, 06:58 PM
