JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
squish squish from steering wheel ?
Hello,
Last year, I had to remove my Momo steering wheel in order to access signal light switch for homemade repair. Using 101 projects, I was succesfull on the switch repair, but after completion of the project, I am left with this squish sound when I turn the steering wheel. I have jacked up the front wheel to have a better chance at locating the source of the noise, but to no avail. Noise seems to be coming from a plastic part attached to steering column. Do you have any ideas ? Thanks. |
Wayah Road Warrior
I know exactly what this is (if your description is accurate).
You need to lube the horn contacts in the steering wheel hub. Use a di-electric grease. You can get that at Auto-Zone (usually in a little tub on the sales counter) for about a buck.
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) |
JCFL
horn contacts in the steering wheel hub ?
Hi shadetree 930 - you wouldn't have a picture by any chance ?
Your explanation sounds accurate, because I was kind of doubting horn contact ring (plastic piece ) was part of the problem. Thanks. |
Wayah Road Warrior
No pic but it is self evident if you pull the steering wheel. Not sure what year you have but on the 87-89 seris you
Takes all of 10 minutes. Now, I am going to do a search. I know there was a thread on this some time back. Here ya go .... Post #10 has a pic. 930S steering wheel sounds... "scratchy"
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) Last edited by Shadetree930; 03-20-2009 at 04:38 AM.. |
