Fog light switch
Does anyone know the easiest way to access or replace the fog light switch on an 84 911 Carrera? My fog lights don't turn on, and I think it's either the fog light switch or one of the connections on it.
Also, does anyone know which connection on the back of the headlight switch is for the fog lights? Thanks |
if you pull out the fresh air blower assembly, you can gain access to all of that stuff.
Just to make sure, you do realize that your head lights (no high beams) have to be on for them to work...right?
Make sure EVERYTHING else is A-OK before you start taking that switch apart. Highly unlikely that it's the switch.
pozee |
muck-raker
Sounds like the turn signal switch needs repair/replaced. Does both your highbeam/lowbeam work?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Opposite problem.
My fog lights don't shut off! Mike.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car |
