riderosa
Motul RBF 600 and ATE Super Blue
I recently installed Carrera front brakes on my 82 911 SC. Do I have to purge all of the ATE super Blue brake fluid before I can use Motul RBF 600? The ATE fluid is only a few months old.
Both ATE and Motul 600 are DoT 4 fluids and are completely interchangeable/mixable.
The issues arise w/ DoT5.1(& DoT 5 which you should never use) which are specified for some ABS systems. There the issue is more viscosity than chemistry
I just did this change ,it took a lot of fluid to flush out the Super Blue on my 930 calipers.
The Motul still had a slight tinge the super blue die must be pretty strong I suggest purging the super blue as low as you dare in the resevoir
www.facebook.com/pages/Bournville-Frameworks |
riderosa
Thank you
