rhk109's Avatar
engine/tranny mount washers
How many of those big washers do I need on my motor and transmission mounts? When I dropped the engine I only had 1 one each corner. Wayne's diagram shows 2 per corner. After some searching I found others who only had 1 per corner. Is this model year dependent? On the chassis for the tranny mounts it looks like a washer is welded to the chassis, so why do I need another?
rhk109
'76 911 3.0 Webers
Old 03-01-2004, 09:30 AM
Friend of Warren
The engine mounts use two of the "washers" one on either side of the mount. The tranny just uses one on the bottom side of the mount.
Kurt V
Old 03-01-2004, 09:44 AM
fuelie600's Avatar
My car has two on each mount. Tranny and engine. One top & one bottom.
Evan
1987 sun roof coupe
Old 03-01-2004, 10:20 AM
Friend of Warren
Engine mount:
Tranny mount:
Kurt V
Old 03-01-2004, 10:27 AM
Search did not help so I'll follow on to this thread, although I'm asking about the G50 on my '88. I have the 4 washers out and just noticed that there are two that are basically smooth and tow that have a raised area near the center where the large bolt goes through. Can someone with a G50 tell me which washers go on which side of the rubber disc thing in the tranny mount. From the diagram in the Porsche parts catalogue it sort of looks like the smooth washer goes below and the one with the raised section goes on top but that's not a very detailed diagram and I want to make sure since there appears to be a susbstantial difference in the two versions.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-24-2009, 01:06 PM
aj88cab's Avatar
Maybe this will help. Its my '88 G50 with the Pelican PEL-RSRMTM poly-graphite mounts. You can see which washer I used on the bottom. Pretty sure itwas the same washer on the bottom with the factory mounts I replaced.
Good Luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 03-24-2009, 02:43 PM
Andrew, thanks, it looks like from your pic the "smooth" washer is used on the bottom which is what I was thinking.
thanks,
Buck
'88 Coupe, '87 Cab,
Old 03-24-2009, 04:14 PM
