AirBorne!
Guard LSD, how does it benefit the car under braking?
I just put a Guard LSD in my gearbox, along with some shorter gears. The car is fun, fun. It "appears" to brake in shorter distances? Is that rear or is the rear end just more stable?
Can someone chime in an 'splain to me?
wj
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 03-28-2009, 12:09 PM
AirBorne!
Mean to say, Is that real or is the rear end just more stable under braking?
GrantG's Avatar
Yes, a Guard LSD will give large benefits under braking and corner entry. It acts as if the rear axle is solid (left and right rears must travel at same speed), so there is far less wiggle and squirming under braking, which gives shorter braking distances and more stability, which also leads to more driver confidence and faster laptimes. Because of the LSD, there is also less tendency for one of the rear wheels to lock under hard braking (since the wheel which would tend to lock is kept at the same rotational velocity as the other wheel). An LSD is a huge benefit in these and the more obvious ways (corner exit and uneven friction surfaces from right to left sides of the car, etc.).
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 03-28-2009, 12:19 PM
175K911's Avatar
As GrantG said, with the rear locked up to a certain degree under decel (can be hard decel without using the brakes) the back of the car is more linear. Especially true if you tend to trail brake into a turn as I do in certain types of turns. The tradeoff can be greater push in low speed (2nd gear) turns under hard accel.
When I installed the Guard in my '86 I set it for 50/80 (50% lockup on accel and 80% on decel) and it really stabilized the car. Most noticable at places like VIR where you have to decel from 130+ into a turn 1, a tight 2nd gear turn.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-28-2009, 01:00 PM
AKA SportsCarFan
FastCarFan's Avatar
In addition to his rear-end, JackMan just got his car back from a front-end repaint & it looks fantastic. Maybe he will post a pic for all to enjoy.
Doug Miller
1988 Guards Red Carrera
Old 03-28-2009, 01:42 PM
Max Sluiter
Flieger's Avatar
Oh, so he's holding out on us...
Old 03-28-2009, 01:46 PM
AirBorne!
Yeah, yeah .... I'll get some pixs up today. Hopefully the pixs will do the paint justice. I had the front end resprayed, new windshield installed, some headliner work done, and some other odds and ends, and had the rest of the paint buffed with rubbing compound. Wow.
wj
Old 03-29-2009, 03:25 AM
Ed do you know what this relates to in terms of ramp angles and do you know how many plates and what is the preload setting.
I am trying to get some idea of the variations being used and the impact on handling.
Old 03-29-2009, 05:25 AM
