MFI ID need some help
I have two MFI pumps and could use some help in identification. The side plates both read the same ...PED6KL 60/120 R3Y and EP/RLA 1/43 R
The top plate is probably to one that can be decoded... The first reads 1301 2468 then 0408-126-015 The second reads 2270 9105 then the same 0408-126-015 Thanks for the help. Speedo |
72/73 t pump
ok...
Thanks...what is the resource for "decoding" them? A link maybe?
Speedo |
You can find them here
http://www.pelicanparts.com/techarticles/911_MFI/TipMFI.htm
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
