Gordo2's Avatar
Question What are you guys using as "parts washers" at home
Not sure this is off topic or whatever...
What are you folks using as parts washers (tub with cleaning/degreaser fluids to clean up parts) at home?
-I've seen people mention using dishwashers for some parts - that ain't flyin' in my house.
-I've considered buying a cheap parts washer (Harbor Freight).
-Also considered buying a cheap deep sink to soak parts in.
What's everyone else using to clean up greasy parts?
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-02-2009, 09:38 AM
I have the cheap HF one. Problem is it can't be used with solvents...only soapy like stuff, (which they are happy to sell you at HF).
But I prefer mineral spirits, etc. so I ended up buying a flat plastic tub with a lid from Wal Mart. Over about 2 years, the mineral spirits have warped the shape of the tub a bit, but it's still in good enough shape to seal up when not in use.
The prevailing wisdom on this board is to buy the "right tool" and I think a parts washer that you can put solvents in would be ideal. But my tray-o-spirits works well enough for me.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 04-02-2009, 09:48 AM
I used the HF one with the citrus-based cleaner it's intended for, which is widely available at all big chain auto-parts stores and is cheap. I have to say the HF cleaner was junk, but I only intended to use it for one rebuild.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-02-2009, 10:12 AM
(the shotguns)
berettafan's Avatar
i learned the hard way that painted parts cleaners can't take just any liquid.
goofy design if you ask me. a $3 throw away turkey roasting pan from the dollar store works well for some stuff.
Old 04-02-2009, 10:19 AM
Just wondering. Since citrus-based cleaner is water soluble, what are the long-term effects of it stored in a metal parts tank? Same with moisture in a petroleum-based cleaning tank?
Old 04-02-2009, 10:20 AM
I got a 30 gallon Safety-Kleen system with light , pump, screen for free from a friend with brand new Agitene cleaning fluid in a 30 gallon drum. Works like a charm, doesn't ruin your skin and dries off cleaned parts in a few minutes. Its the nuts...
Old 04-02-2009, 05:58 PM
Don't bother with the Harbor freight one. It's crap. The spigot broke off mine and now I just use it as a table.
Old 04-02-2009, 06:18 PM
Keepin' it Simple...
R_Builder's Avatar
The is no substitute for lacquer thinner and elbow grease...
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 04-02-2009, 06:19 PM
Slumlord
Porsche_monkey's Avatar
A varsol based re-circulator type, and a vibratory bowl with ceramic stones.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-02-2009, 08:22 PM
3.2 CAB's Avatar
I have a free standing, 30gal. unit. It has the solvent pump of course, along with a filtration system, with a sludge sump built into the bottom of the upper section. The lid is about 4'x2' with the cleaning tank area being about 18"deep. You can put a lot of items in it. I also have a portable dishwasher that someone I knew was going to throw away, because they were getting a new built in type washer. That dishwasher has cleaned a lot water safe items. I even use it for cleaning my black powder, stainless steel, Remington 1858 .44 matched set. It makes quick work of the black powder soot and crud, and the parts come out looking like new again. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 04-03-2009, 12:42 AM
Wer bremst verliert
JohnJL's Avatar
Don, you got a pic of that FJ60?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-03-2009, 12:53 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Wife
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 04-03-2009, 04:29 AM
diesel fuel and a heavy tin tub that looks like a big heavy duty turkey baster
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-03-2009, 04:36 AM
Gary H 1978 911 SC
Maytag 3600, My wife prefers all our appliances are maytag.
Old 04-03-2009, 04:37 AM
cbush's Avatar
I use my large flat oil change tray bucket with gasoline for large, really oil caked parts, and use MEK with steel wool (0000) and a wire brush or shop towel for smaller parts. I like MEK better than laquer thinner because it does not evaporate as fast, and it is great for taking off glues and sealants. Proper ventilation is key!!!
Chuck
70 & 75 911S
96 993 C4S
'10 F-150
Old 04-03-2009, 07:07 AM
Fast Corners's Avatar
A parts cleaner with Mineral Spirits. You can pick them up pretty cheaply and the mineral spirits I get from Home Depot.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 04-03-2009, 07:14 AM
MBruns for President
JeremyD's Avatar
What he says - get the concrete mixing tub at Home Depot. Get a collection of cleaning brushes. Big enough to soak parts overnight - scrub with a brush - simple clean, then rinse - you have a clean part...
Old 04-03-2009, 07:19 AM
cbush, "proper ventilation" is only a small part of it. MEK, a serious carcinogen, is rapidly absorbed through the skin, and if you've found MEK-impervious work gloves, good on you. If not...
Stephan Wilkinson
Old 04-03-2009, 07:27 AM
AutoBahned
RWebb's Avatar
that is a good solution -- you can easily discard the used fluid at any Haz Waste site - or even filter it and burn it in an old tractor or truck
also, diesel doesn't volatilize too badly and is not nearly as toxic as some cleaning fluids
the next step up would be to rent a Safety Kleen outfit and let them handle the disposal - not needed unless you rebuild several major units in a short time.
MEK is one of the most dangerous things you can use - be sure you have good cancer insurance before using it. Same for your family, who will all be exposed to some degree.
Old 04-03-2009, 10:23 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
A dish washer. Works great!
Now I just can't figure out why all of our dishes have this strange film on them.
Seriously though, a used dishwasher is probably cheaper than a good parts washer. It is surprising how well it works. The soap can be pretty harsh on aluminum though.
1981 SC ROW Coupe
Old 04-03-2009, 11:29 AM
