-   -   I like the RS Door panels but the strap opener is chintzy. Is there an alternative? (http://forums.pelicanparts.com/porsche-911-technical-forum/467211-i-like-rs-door-panels-but-strap-opener-chintzy-there-alternative.html)
JonT 04-05-2009 10:00 AM
Is there a metal lever substitute for the strap on the RS door panel? Wondering if anyone has tried this or if there is a similar product available.
fat cab 04-05-2009 10:17 AM
metal adds weight,defeats the purpose of the RS panel.. you could call appbiz.com they might.
RWebb 04-05-2009 10:30 AM
you could use those plastic pulls that PAG used for something or other
FIAT, IIRC
wax105 04-05-2009 01:44 PM
Pay more, get less, go faster.........
Weight kills!
JohnJL 04-05-2009 02:42 PM
I used a piece of rockclimbing sling instead. Light, available in any color you like and strong.
Rrrockhound 04-05-2009 03:58 PM
look here:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/466827-unbreakable-rs-door-pull.html
jpnovak 04-05-2009 04:59 PM
I used a strip of cowhide from a leather store. A 3/4" wide scrap was a few dollars. Just put two holes in it and screw in place.
teamfee3 04-05-2009 05:04 PM
Leather strap and handle
http://forums.pelicanparts.com/uploa...1238976217.jpg
joefrantz 04-05-2009 05:34 PM
Assuming you are referring to the door opening strap, appbiz is making some stitched straps from either leather or vinyl (not sure which -- or maybe both).
Also, I've seen pictures of a 914 door opening lever used in an rs type panel.
If you're going to put it in your SC, you would have to change your opening mechanism to the earlier type to use the 914 option.
teamfee3 04-05-2009 06:02 PM
Leather strap shown above, not flimsy or chintzy. A little stiff initially but appear to break in.
