I like the RS Door panels but the strap opener is chintzy. Is there an alternative?
Is there a metal lever substitute for the strap on the RS door panel? Wondering if anyone has tried this or if there is a similar product available.
1980 911SC Targa 3.6L
Old 04-05-2009, 10:00 AM
fat cab's Avatar
metal adds weight,defeats the purpose of the RS panel.. you could call appbiz.com they might.
Old 04-05-2009, 10:17 AM
AutoBahned
RWebb's Avatar
you could use those plastic pulls that PAG used for something or other
FIAT, IIRC
Old 04-05-2009, 10:30 AM
wax105's Avatar
Pay more, get less, go faster.........
Weight kills!
74' Coupe 3.6 Track Car
VW passat avant 4motion 1.8T
CRG Kalifornia 125Rotax (Sold)
Old 04-05-2009, 01:44 PM
Wer bremst verliert
JohnJL's Avatar
I used a piece of rockclimbing sling instead. Light, available in any color you like and strong.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-05-2009, 02:42 PM
Rrrockhound's Avatar
look here:
The unbreakable RS door pull
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 04-05-2009, 03:58 PM
I would rather be driving
jpnovak's Avatar
I used a strip of cowhide from a leather store. A 3/4" wide scrap was a few dollars. Just put two holes in it and screw in place.
Old 04-05-2009, 04:59 PM
zugelassener benutzer
teamfee3's Avatar
Leather strap and handle
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 04-05-2009, 05:04 PM
joefrantz's Avatar
Assuming you are referring to the door opening strap, appbiz is making some stitched straps from either leather or vinyl (not sure which -- or maybe both).
Also, I've seen pictures of a 914 door opening lever used in an rs type panel.
If you're going to put it in your SC, you would have to change your opening mechanism to the earlier type to use the 914 option.
Joe Frantz
73 911 T
Old 04-05-2009, 05:34 PM
teamfee3's Avatar
Leather strap shown above, not flimsy or chintzy. A little stiff initially but appear to break in.
32C #7
Old 04-05-2009, 06:02 PM
