Designer King
Paulporsche's Avatar
I need a WUR for testing
Some of you may have read my trecent thread on WUR problems.
I have tried 3 vac assist WURs, including one that was rebuilt, and am unable to get the control pressures to rise, no matter what the temp or amount of time.
Does someone have a known good vac assist WUR I can borrow short term to try on my engine and see if it is my current WUR or something else @ fault?
If someone within Canada has one that will cut down on customs hassles, but I'll take one from just about anywhere.
The WUR I'm using is 0-438-140-045, but probably any known good vac assist one will do. The control pressures for the above are approx 1.3 bar cold and 3.4 bar warm.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-06-2009, 07:03 AM
Designer King
Bump for west coast Pelicans.
Paul
Old 04-06-2009, 09:47 AM
