viscirid's Avatar
Front Jack Point Question
I know it has been visited a thousand times but I just want to make sure I'm going to use the right point to jack up my car and not damage anything.
This point is right behind the front wheel. Is this a safe point to jack the front up on my 88 911? I'm guessing this is the point designed for a four point lift, but is it safe to jack on?
Thanks.
V.
88 Carrera Cab
Old 04-08-2009, 07:36 AM
sudo apt-get purge 930
equality72521's Avatar
I use the jack pad inserted in the jack hole just in front of the rear tires. This lifts the whole side of the car, front and rear together.
--clutch-monkey
Old 04-08-2009, 07:45 AM
Friend of Warren
Yes you can jack the car up there.
Kurt V
Old 04-08-2009, 07:48 AM
a.k.a. G-man
Geronimo '74's Avatar
I do not have these jack points shown on the photo. Is that normal?
Old 04-08-2009, 09:41 AM
muck-raker
kidrock's Avatar
It is safe to jack the front at that point, just be sure to not crush the oil line.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-08-2009, 09:44 AM
I don't either.
--clutch-monkey
Old 04-08-2009, 09:57 AM
dshepp806's Avatar
Like Mark stated,......I, too, lift the entire side FIRST, then apply the other points at the jack points listed within the Bentley,..this pic is easily found with a search (or a book-look)....
I've used this point once before as additional support, not primary,..still: the Bentley pic will take you "home", as to what's SAFE.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-08-2009, 01:38 PM
Bill Verburg's Avatar
Those lifting points are only on the newer cars.
on an older car put a piece of 2x4 between the tub and jack at the flats in the corners, lift there
Bill Verburg
Old 04-08-2009, 02:30 PM
GothingNC's Avatar
I use a hockey puck in the same area as the photo and jacking one side lifts the entire front end high enough to place the jack stands.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 04-09-2009, 03:48 AM
