My 911's heat exchangers have rotted away so I bought a set of used heat exchangers on e-bay, they do fit but I am unable to get them to seal, the old ones had a collar that protrudes and fits into the cylinder head but the replacements do not, are there any tricks of the trade to get them to seal? I have replaced the gaskets with new ones purchased from Pelican parts.
Sorry, it's a 1983 911 Targa, 3.0L
need to see pictures of the exchanger and the exhaust ports.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
grateful user
leak
get a good file and go to town, its very hard metal and it will take a while, and buy the oem gaskets. mine used thin flange ones were the same way but i got them to quit leaking.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
