-   -   Am I the first idiot to do this? (http://forums.pelicanparts.com/porsche-911-technical-forum/467495-am-i-first-idiot-do.html)
squidmarks 04-06-2009 03:52 PM
After a total engine rebuild, transmission rebuild, complete rotisserie body rebuild I was ready on Saturday to turn the key. Rebuilt suspension and brakes were on, wheels on the ground and engine and transmission were installed. Filled it up with fluids and after taking care of a couple little leaks it was time to fire it up. Nothing happened when I turned the key. Right...a couple fuses need to be in. Put in the fuses and turned the key, saw the oil pressure rise but no firing. I spent the entire day Saturday checking the ignition, then most of Sunday checking the fuel system then late Sunday afternoon I finally got it to sputter when I put the accelerator to the floor. But, it backfired so hard that it blew the pop-off valve right out of the airbox. I'm glad I had installed that valve, or I would have had an exploded airbox. That backfire made me re-check the ignition. I finally checked the firing order by reviewing Waynes book I used to rebuild the engine. Yes, I had them wired exactly like it shows in the picture....but then I read the fine print in the caption below the picture that said:
"Swap plugs 6 and 5 along, with plugs 3 and 2 for the SC and Turbo configuration"
It was one of those moments where you're so happy you finally figured out the problem, you're not angry with yourself for screwing it up initially. I switched the plug wires on the distributor and she fired up smooth on the first turn of the key. It was late Sunday night and not the appropriate time to do the 20min high-rev break-in (neighbors would not have appreciated it), so I shut it down after a minute.
Am I the only idiot that's done this?
Geoff
moneymanager 04-06-2009 04:18 PM
Apparently. But I've lots dumber things than that!
Rot 911 04-06-2009 04:46 PM
I can top that. I forgot to reinstall the ring gear when I did my rebuild. Didn't discover it until I tried to start the engine and the starter just spun!
Talewinds 04-06-2009 04:50 PM
Ehh, I did that 2 weeks ago to my wife's old Altima, but I was hardly paying attention whilst doing the work because the car's hardly worth anything.
sc_rufctr 04-06-2009 04:53 PM
That's a classic... (I've done this as well...lol)
Formerly Steve Wilkinson 04-06-2009 04:53 PM
It took me forever to get the wiring right on my new 12-plug dual-ignition distributor when I rebuilt the gold-plated Porsche, and I think I probably even had the engine running backward at one point. Don't feel bad.
Dantilla 04-06-2009 05:02 PM
I'm sure glad I've never done anything stupid.
Porsche_monkey 04-06-2009 05:44 PM
Originally Posted by squidmarks (Post 4590729)
Am I the only idiot that's done this?Geoff
No. Just the first one to confess in public.
sc_rufctr 04-06-2009 05:45 PM
Really?... haha
uwanna 04-06-2009 05:50 PM
Back in the early seventies, I built a very highly modified 2.5L motor. I aquired a Vertex racing magneto from a friend, and thought it would be a cool addition. After building this pristine motor from the ground up and installing, I was ready to fire it up. It would not start, just back fired and sputtered. Turns out when I installed the Vertex with the plug wires I had fabricated, I hooked them up, attaching No1 from the Vertex to No1 cylinder, No2 from the magneto to cylinderNo2, and so on!! DUH!!! After getting them rehooked up in the correct firing order, I felt like anything but a mechanic, more like a f#@king idiot!
But when all was correct, the car was a rocket.
Grant
Nine9six 04-06-2009 06:24 PM
Ouch! That had to hurt:eek:
mtnfir 04-06-2009 06:41 PM
I drilled a hole in my kegerator for an extra keg and managed to hit on of the coolant lines. wifey was pissed
Wayne 962 04-06-2009 07:13 PM
Right-o. I've done that before, hence I put it in the book!
-Wayne
304065 04-06-2009 07:22 PM
One of these days I'm going to get a tattoo that says 162534
rajah911 04-06-2009 11:04 PM
Kurt - sorry mate, but that is absolutely PRICELESS!!! :D
One of the very rare times that I have literally "laughed out loud" at something that one of my fellow 'drongo's' has done in a moment of madness (trust me, I've had many a few myself!!).
It's lovely to see that people on this wonderful forum are humble enough to admit such mistakes to all and sundry, and you all have my utmost respect for doing so :)
regards,
JP911 04-07-2009 08:44 AM
Nope, I did it. The previous owner of my '76, which still had the 2.7, decided that SC engine decals would look lovely in the engine compartment. I followed these decals when replacing the cap, rotor, and ignition wires. Same result as you, including the dislodged popoff. Took me a few days to retrace my error. Needless to say, the SC decal with the dizzy rotation and order was promptly removed.
equality72521 04-07-2009 09:29 AM
Mine is 162435, a sequence I will never forget in my life. Ironically, it's the numbering sequence for connecting a three phase motor winding. After spending 15 years winding motors you don't forget it. Now, years after my motor winding days it is still coming in handy. :D
http://forums.pelicanparts.com/uploa...1239121761.jpg
sailchef 04-07-2009 10:17 AM
Been there, done that, following the Bently's manual. It didn't say anything about SC's dizzy turning the opposite direction.
CBRacerX 04-07-2009 10:42 AM
Done that one better by combining it with improper installation of the distributor. It ran, barely...
RichMink76 04-07-2009 12:01 PM
I did the same thing on my 78 3.0. I did just what the book said, almost. It is one of the best feelings when that motor starts for the first time after the long build process.
Rich
