| Registered Join Date: Apr 2009
				 |  Heat exchanger replacement help.
			My 911's heat exchangers have rotted away so I bought a set of used heat exchangers on e-bay, they do fit but I am unable to get them to seal, the old ones had a collar that protrudes and fits into the cylinder head but the replacements do not, are there any tricks of the trade to get them to seal? I have replaced the gaskets with new ones purchased from Pelican parts.   | ||
|  04-07-2009, 12:29 PM |
			Sorry, it's a 1983 911 Targa, 3.0L
|  04-07-2009, 12:36 PM |
| Registered |
			need to see pictures of the exchanger and the exhaust ports.
				__________________ 1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera | ||
|  04-07-2009, 01:10 PM |
| grateful user |
				leak
			get a good file and go to town,  its very hard metal and it will take a while, and buy the oem gaskets.  mine used thin flange ones were the same way but i got them to quit leaking.
				__________________ fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. | ||
|  04-07-2009, 07:15 PM |
