140 hp Mercury + 16' flat bottom = SCARY!! :eek:
They still sell/use a very similar tool to synch the individual TBs on multi-cylinder motorcycles.
There were very few people I trusted to drive that boat without me being with them. It was a serious death trap. After owning it several years, and learning it cautiously, I was able to drive it "on the edge", and know I was safe. There was so much torque for such a light hull that backing off the throttle too quickly would throw the bow violently to the left. |
So, does anyone use one? :)
Sherwood |
I prefer the Synchrometer, which can be bought in a number of different car-specific forms to fit carburetor throats fairly precisely, no leakage.
Motorcycle instructions:
step 1. warm up engine to normal temperature. shut off engine. step 2. remove the air box lid. step 3. start engine and place the synchronizer on top of one of the throttle bodies, making sure to seal against the bottom of the synchronizer. step 4. turn the center springloaded valve to adjust the red indicator pittle to where it "floats" in the middle of the window. note exact position. step 5. without moving the springloaded valve, place the synchro nizer on the other throttle body and check the location of the red pittle. adjust the throttle body air bleed or throttle rod to the point where the red indicator pittle is in the same position. step 6. if your throttle body has no further adjustment, place one of the throttle bodies setting screw in the center and repeat step 3 to 5. shut off engine. step 7. reinstall the air box lid. |
While idle sync is good, it's more important to ensure equal airflow during part/full throttle if possible.
Sherwood |
Forty years ago I thought it was so much more hi-tech than a piece of rubber hose to your ear described in the Healey 3000 manual....
I have one in the tool box.
How about the two metal tubes, split on one end and oval on the other, for SU carbs? Take the dash-pot tops off insert the split end of the tube into the hole on top of the throttle slide. Insert the P shaped wires into the oval top of the tubes, swivel the ends adjacent to each other and adjust (bend) so the adjacent ends are level with each other. Then start the car and set the idle stops so the ends are at equal heights. Increase the RPM and adjust the linkage so that they rise equally. Shut the motor off add dash-pot oil and replace the tops. |
My question of, "So, does anyone use one?" was an attempt to state the obvious. Of course. This product has been around for at least 40 years. I have one; started using it on my '62 Corvair. I figure there's many thousand of these in tool boxes across the earth by now.
Sherwood |
Got mine when I was 18 for tuning my '63 MGB. Cost about £5! To work on my daily driver now (VW) I guess you need a laptop (£500+),...! :confused: Progress eh? |
| All times are GMT -8. The time now is 03:56 AM. |
