Ubi bene ibi patria
Hawkeye's-911T's Avatar
Tail Light Assembly Question??
Hi Guys
I've done a search and have found plenty of helpful information on tail light re-hab & clean-up. My question is regarding the gaskets/seals. Our host has what appears to be the major lens/housing ass'y. gasket. I cannot find a part number or anything on the gasket shown to the right of the backing plate & above the main assembly seal in the attached photo or the little vertical compartment seals for the individual bulbs. I am absolutely certain one of the board members can steer me in the right direction. All of these seals I have are in a fairly sorry state & need to be replaced. Any advice would be greatly appreciated. Many Thanks in advance.
Cheers
JB
Old 04-12-2009, 03:25 PM
Ubi bene ibi patria
I'm still "at-sea" on this one. Help, anyone
Please & Thanks
JB
Old 04-14-2009, 10:22 AM
My "seal" that was around the rear plate on the tail light Assembly was "Dum Dum" not rubber as the lens seals were.
Lorne M.
83 SC
Old 04-14-2009, 11:10 AM
geoz's Avatar
I think the solution for the smaller vertical seals is simply using pieces of split rubber hose. Not sure about the other seal, i have a later model and don't remember seeing something like this.
Old 04-14-2009, 11:50 AM
dshepp806's Avatar
What year car?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-14-2009, 12:08 PM
Ubi bene ibi patria
It is a 1970 model. That may help explain the lack of info on, or availibility of the seals in question. I may have to 'wing' it as you guys suggest. Many Thanks for your input.
Cheers
JB
Old 04-14-2009, 12:32 PM
