Dottore's Avatar
pardon the silly question...but...
My car comes from Switzerland and has a Swiss "CH" sticker that is absolutely baked on to the back bumper. I suspect it has been there for 20 years or so.
I have tried everything to get this off without damaging the paint, but am at a loss.
Any bright ideas?
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 04-12-2009, 04:11 PM
e p slick's Avatar
Mineral spirits + WD40
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 04-12-2009, 04:32 PM
muck-raker
kidrock's Avatar
+1...also, it may help to warm it up a little before trying to remove it. Use a heat gun (gently) or hair dryer.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-12-2009, 04:34 PM
silver911rdb's Avatar
How about goof off
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 04-12-2009, 05:18 PM
Slumlord
Porsche_monkey's Avatar
Hair dryer should help. Or CAREFULLY use a heat gun on the low setting. Or rags soaked in boiling water .
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-12-2009, 05:26 PM
Banned
If it has been there 20 years I would imagine it is brittle, as well as the adhesive behind it.
The heat gun sounds good to maybe soften it up a little.
I would also try a razor blade and some time and just gently slide behind it. Any damage, if any, to the paint on the bumper could most likely be rubbed out.
A combination of the heat gun and razor blade actually sounds like it would work. Kind of like getting a registration tag off of a license plate.
The goof off or solvent idea probably wont work. Those products are designed to loosen glue but in your case the glue is behind the sticker. The goof off would have to soak through the sticker in order to get to the glue and that is not going to happen.
If you perforate the sticker then the goof off would have a better chance but I would try the heat and blade method first.
I think it will work.
Good luck.
Old 04-12-2009, 06:05 PM
1983 911SC Chiffon Weiss
mlfox's Avatar
AVON "Skin So Soft" - Great for removing old bumper stickers.
Old 04-12-2009, 06:12 PM
PorscheGuy79's Avatar
Heat gun might work, but you gotta think... A sticker on the back bumper next to the muffler is probably used to a lot of heat over the years. Worse case I think soaking it, literally by maybe soaking a sponge with a diluted solution of simple green or a mild adhesive remover (there might be better ideas better than a sponge or solution) and letting it sit (tied on or propped up etc.) might help the razor situation.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 04-12-2009, 06:23 PM
m110's Avatar
Good luck.
I agree. To use goof off or some other spirit you would have to soak it for a while. That would mean removing the bumper which is a pain. Heat, patience and gentle mechanical means to start followed by some solvent once it comes up sounds best.
Besides waiting the swiss, why do you want to remove it? If it's been there that long then the paint will be faded around it and you will possibly have an outline of the sticker remaining.
1988 Carrera Coupe
Old 04-12-2009, 06:30 PM
Valid point, the stupid "car bra" situation. You could always cover it up with a German one!
Matthew
Old 04-12-2009, 06:35 PM
m110's Avatar
..sorry..
I meant to say:
Besides hating the swiss (kidding of course)
1988 Carrera Coupe
Old 04-12-2009, 06:42 PM
"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
how about just leave it there wher it was for ~20years...........
G-Man
89 964 C4
86 930
Old 04-12-2009, 06:55 PM
Send a message via Yahoo to jjrowe
I would do the following:
Use a heat gun or hair dryer and a plastic scraper or your finger nails to slowly scrape the sticker off. This is going to be time consuming but keep heating and scraping until the sticker is gone. Now you will be left with the glue. There are some citrus products for sticker removal that I would use next. Spray some on and let it sit, then wipe. Repeat until glue is gone, it will take a while.
I would not use goof-off. it will work, but its going to take some of your paint with it.
- Jesse
Old 04-14-2009, 08:59 AM
WUNDERWAFFE
JINKATIN's Avatar
You may also try a steamer, it works well to remove window tint and decals.
Good luck,
Jinkatin
86 911 Carrera
Old 04-14-2009, 12:15 PM
